LinuxCNC/gmoccapy
20 Oct 2013 23:35 #40092
by laurits11
LinuxCNC/gmoccapy was created by laurits11
I am trying to install gmoccapy GUI , but i keep getting this error when i open the program .. dose anybody know what the problem can be ?
thanks laurits
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.3
Machine configuration directory is '/home/dell/linuxcnc/configs/sim/gmoccapy'
Machine configuration file is 'gmoccapy.ini'
INIFILE=/home/dell/linuxcnc/configs/sim/gmoccapy/gmoccapy.ini
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=gscreen -c gmoccapy -d
Starting LinuxCNC...
Starting DISPLAY program: gscreen
Can't execute DISPLAY program gscreen -c gmoccapy -d
Killing task linuxcncsvr, PID=10390
Killing task milltask, PID=10482
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
10390
PID TTY STAT TIME COMMAND
10482
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 4959.782638] I-pipe: Domain RTAI registered.
[ 4959.782643] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 4959.782645] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 4959.782731] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4959.782733] PIPELINE layers:
[ 4959.782735] fc6ffe20 9ac15d93 RTAI 200
[ 4959.782737] c085cb20 0 Linux 100
[ 4959.797638] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4959.798009] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 4959.798014] RTAI[sched]: hard timer type/freq = APIC/20781141(Hz); default timing: periodic; linear timed lists.
[ 4959.798017] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2493590000 hz.
[ 4959.798019] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4959.798082] RTAI[usi]: enabled.
[ 4959.818702] RTAI[math]: loaded.
[ 4960.277762] RTAI[math]: unloaded.
[ 4960.288814] SCHED releases registered named ALIEN RTGLBH
[ 4960.352245] RTAI[malloc]: unloaded.
[ 4960.452009] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4960.454063] I-pipe: Domain RTAI unregistered.
[ 4960.454205] RTAI[hal]: unmounted.
thanks laurits
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.3
TASK=milltask
HALUI=halui
Cleanup done
10390
10482
21 Oct 2013 01:33 #40093
Replied by cmorley on topic LinuxCNC/gmoccapy
How did you start this ?
It says linuxcnc 2.5.3 - Gmoccapy will only work with the development version (2.6)
Chris M
Chris M
21 Oct 2013 01:36 #40094
by laurits11
Replied by laurits11 on topic LinuxCNC/gmoccapy
okay i see . i will try to install vision 2.6 then
thank you
thank you
21 Oct 2013 02:00 #40097
by laurits11
Do you know how to get and install v. 2.6?
21 Oct 2013 02:08 #40099
by laurits11
i found this page buildbot.linuxcnc.org/ but i have no idea what to do with this code ?
deb buildbot.linuxcnc.org/ lucid master-sim
deb-src buildbot.linuxcnc.org/ lucid master-sim
21 Oct 2013 02:43 #40101
by laurits11
i managed to get it to work
22 Oct 2013 03:00 #40148
by newbynobi
Replied by newbynobi on topic LinuxCNC/gmoccapy
There is also a WIKI explaining a lot of gmoccapy and also Videos on YouTube.
Norbert
Norbert
