Gremlin Display Buttons
08 Jan 2014 00:45 #42444
by gww250
Gremlin Display Buttons was created by gww250
I'm having good luck with John's tutorials but need help on the method to incorporate the various display window options with Gremlin. My default is 'perspective view'. What do I need to do to add the other 'views' in my prototype gui I'm working on?
08 Jan 2014 06:08 #42461
by newbynobi
Replied by newbynobi on topic Gremlin Display Buttons
Just take a look at gmoccapy source code, as i am using most options there.
Norbert
Norbert
08 Jan 2014 07:38 #42468
by gww250
Replied by gww250 on topic Gremlin Display Buttons
thanks for the tip. How do I obtain a copy of that>
08 Jan 2014 15:02 #42477
by newbynobi
Halo nameless,
if you are allready working with master, it is allready on your PC,
~/linuxcnc-dev/share/gscreen/skins/gmoccapy/gmoccapy_handler.py
is the file to look for.
Here is the WIKI from gmoccapy:
gmoccapy WIKI
If you just want the code, then look at:
gmoccapy_handler.py
Norbert
gmoccapy WIKI
gmoccapy_handler.py
Norbert
08 Jan 2014 20:41 #42497
by gww250
Thanks Norbert. I found it right after I posted but could not get back on the forum to thank you. We're building the gui for a 2500w laser so the plasma configuration is of great interest since the THC head control is similar to the lasers autofocus mode.
Gary
Gary
09 Jan 2014 02:51 #42515
by newbynobi
Halo Gary,
if you need special "plasma" button or controls for your laser outfit, let me know, it should not be so complicated to adapted to laser needs.
Norbert
Norbert
Time to create page: 0.061 seconds
