ngcgui,pyngcgui support for gcmc
21 Feb 2014 00:07 #44014
by dgarrett
ngcgui,pyngcgui support for gcmc was created by dgarrett
ngcgui (and pyngcgui) now support Bertho Stultien's
Gcode-meta-compiler (gcmc) in git master and in recent
buildbot debs.
Ngcgui creates entry boxes to simplify testing and use of:
a) single-subroutines gcode files (.ngc)
b) gcode meta compiler files (.gcmc)
Notes:
1) gcmc (version >=1.4.3) must be installed independently and
located as an executable file in the user PATH, see:
www.vagrearg.org/content/gcmc
2) linuxcnc can be built for run-in-place (RIP)) from git master
or installed from a recent buildbot deb (19Feb2014 or later),
instructions at:
buildbot.linuxcnc.org
3) Example ini files for demonstration are located:
configs/sim/axis/ngcgui/ngcgui_gcmc.ini
configs/sim/axis/ngcgui/pyngcgui_gcmc.ini
configs/sim/gscreen/ngcgui/pyngcgui_gscreen_gcmc.ini
configs/sim/touchy/ngcgui/pyngcgui_touchy_gcmc.ini
4) The examples use .gcmc files located in: nc_files/gcmc_lib
nc_files/gcmc_lib/square.gcmc
nc_files/gcmc_lib/drill.gcmc
nc_files/gcmc_lib/star.gcmc (Bertho Stultiens)
nc_files/gcmc_lib/wheels.gcmc (Alan Battersby)
5) To modify the examples or create new .gcmc files:
a) create your own directory, for example:
$ mkdir ~/linuxcnc/myfiles
b) copy or edit your own .gcmc files, example for a deb install:
$ cp /usr/share/linuxcnc/ncfiles/gcmc_lib/square.gcmc ~/linuxcnc/myfiles/mysquare.gcmc
c) add your directory to the subroutine path defined in the ini file.
Example:
[RS274NGC]
SUBROUTINE_PATH=~/linuxcnc/myfiles:../../nc_files/ngcgui_lib:../../nc_files/gcmc_lib:../../nc_files/ngcgui_lib/utilitysubs
(above is all on one line,directory names are separated by colons ()
Note: Linuxcnc searches for a subroutine file by name following the
[RS274NGC]SUBROUTINE_PATH. The first file found with a
matching name is used.
d) add your files to the ini file in the [DISPLAY] stanza, example:
[DISPLAY]
TKPKG = Ngcgui 1.0
NGCGUI_FONT = Helvetica -12 normal
NGCGUI_PREAMBLE = in_std.ngc
NGCGUI_SUBFILE = square.gcmc
NGCGUI_SUBFILE = mysquare.gcmc
# specify "" for a custom tab page
NGCGUI_SUBFILE = ""
(including a custom tab page allows you to search for .ngc and .gcmc
files as long as they are in the SUBROUINE_PATH)
6) After creating your own .gcmc file, add tags within the file to
identify variables requiring entry boxes. For example, to tag a
variable named frate, include the line:
//ngcgui: frate = 100;
To specify a default value and label, use:
//ngcgui: frate = 100; //, Feed Rate
(See the included demo .gcmc files for more examples.)
7) When a .gcmc file is selected, ngcgui submits it to the gcmc compiler,
and places the resulting gcode file in the [DISPLAY]PROGRAM_PREFIX
directory for use by Linuxcnc.
8) Ngcgui can combine .gcmc and .ngc files from multiple tab pages
Additional Referencess:
www.linuxcnc.org/docs/devel/html/gui/ngcgui.html
www.linuxcnc.org/docs/devel/html/config/...b_rs274ngc_section_a
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...fb3cd177b538cb3e67fe
buildbot debs.
Notes:
instructions at:
Example:
[RS274NGC]
[DISPLAY]
TKPKG = Ngcgui 1.0
NGCGUI_SUBFILE = ""
21 Feb 2014 00:46 #44021
by ArcEye
Replied by ArcEye on topic ngcgui,pyngcgui support for gcmc
Nice one Dewey,
I really must get around to updating to your new version of ngcgui, the trouble is the old one works so well, I haven't had the incentive!
21 Feb 2014 18:24 #44039
by Rick G
Replied by Rick G on topic ngcgui,pyngcgui support for gcmc
Just keeps getting better and better.
Rick G
Rick G
Time to create page: 0.149 seconds
