Show velocity in master
- guymalpass
20 Jul 2014 20:51 #48973
by guymalpass
Show velocity in master was created by guymalpass
I've just installed master as I wanted to try out the new trajectory planner but I cannot get the current velocity to show, the option within the view menu has no effect. Is there any way of getting this back as it would be nice to see how well the new trajectory planner adheres to the programmed feed rate?
Many thanks,
Guy Malpass
Many thanks,
Guy Malpass
20 Jul 2014 21:34 #48974
by ArcEye
Replied by ArcEye on topic Show velocity in master
Hi
I am guessing that you have 'Show Offsets' enabled
Not only does this litter the whole screen with DROs, making it hard to see the plot, it seems to knock out the velocity display.
If you disable the offsets, the velocity should display properly
The following user(s) said Thank You: guymalpass
- guymalpass
21 Jul 2014 05:36 #48989
by guymalpass
Replied by guymalpass on topic Show velocity in master
Thank you, I will try this tomorrow and your absolutely correct, the screen is littered with other readouts!
- guymalpass
23 Jul 2014 05:06 #49035
by guymalpass
All fixed, exactly as you said.
Time to create page: 0.062 seconds
