Custom Gui tutorial Issue
08 Nov 2014 19:46 #52941 by ww34ww34
Hi all,
I'm just installed linuxcnc from debian.hybrid.iso
And now I'm tryng to follow
gnipsel.com/linuxcnc/gui/gui01a.html
But when i put "VCP Toggle ESTOP action" on windos (Point 8 of tutorial) the glade environnement close itself.
Someone know why?
08 Nov 2014 19:57 #52943 by ArcEye
Replied by ArcEye on topic Custom Gui tutorial Issue
You are obviously a glutton for punishment, first kernel building, now glade :laugh:
First thing, Debian 7 uses glade3, based on gtk3. This is not compatible with gladevcp which needs glade 2.
You need to remove glade3, add the lines to /etc/apt/sources.list to pull from the Squeeze repos and fetch glade2 from there.
Only then will anything to do with gladevcp work
The following user(s) said Thank You: ww34ww34
08 Nov 2014 21:11 #52946 by ww34ww34
Replied by ww34ww34 on topic Custom Gui tutorial Issue
Ehm...yes :blush:
I'm working hard to learn everything.
(And After that custom player i have i harder question, a miling machine with two Z axes. But i keep it for later. :whistle: )
I think i have solved the problem. Or just find a workaround.
On the VCP Action just right click and click "add wigest as top level".
Than you can use it,
Thanks ArcEye
08 Nov 2014 23:05 #52951 by ArcEye
The man who wrote the tutorials, JT, is the one to ask about gladevcp specifics.
I just know that it will not even run on gtk3 and you have to downgrade, because I had to do it to run an example a while back
09 Nov 2014 00:22 #52958 by ww34ww34
I'm actually use glade 2.
Regards
09 Nov 2014 03:07 #52968 by BigJohnT
Replied by BigJohnT on topic Custom Gui tutorial Issue
All the tutorials I wrote are based on what comes on Ubuntu 10.04... I think some of them even state that.
JT
