custom Gui
25 Nov 2014 16:47 #53383
by ww34ww34
custom Gui was created by ww34ww34
I'm trying to write a custom GUI taking example from gmoccapy gui..
But when i try to catch all error with this code
I can't catch this error:
that was printed only on console without
"catched %s,%s" word
i found this codein
/src/emc/motion/command.c
so i suppose with polling error i can cath it. But until now i try everything and nothing worked for me.
Anyone know why?
__init__(self):
gobject.timeout_add(100, self._periodic)
def _periodic(self):
self.stat.poll()
error = self.error_channel.poll()
if error:
kind, text = error
print "catched %s,%s" (kind, text)
Emit interp-run
USRMOT: ERROR: invalid command
move on line 32 would exceed joint 2's positive limit
i found this code
reportError(_("%s move on line %d would exceed joint %d's positive limit"),
move_type, id, joint_num);
Anyone know why?
25 Nov 2014 21:27 #53394
by ww34ww34
Replied by ww34ww34 on topic custom Gui
Problem solved bu myself.
periodic need
return True
at end to work.
periodic need
return True
at end to work.
26 Nov 2014 01:41 #53412
by newbynobi
Replied by newbynobi on topic custom Gui
if you do not return True, it will work only once, so only one cycle, but you have to poll continiously.
So you did right!
Norbert
So you did right!
Norbert
The following user(s) said Thank You: ww34ww34
