Custom GUI and PyVCP
01 Jun 2015 11:46 #59295
by sdfzz
Custom GUI and PyVCP was created by sdfzz
Hi all,
I have a custom GUI and PyVCP panel. I can run them in two separate windows, and they work great.
However, I want to embed the PyVCP panel into my GUI. I know this can be done for AXIS GUI (like: linuxcnc.org/docs/html/hal/images/gs2_panel.png).
But, when I tried it on my GUI (though ini and hal files) the PyVCP panel does not show up.
I can include my PyVCP to AXIS GUI without any problem...
Is there a way to include a PyVCP panel to a custom GUI?
Any help will be appreciated
Regards,
Steve
Regards,
Steve
01 Jun 2015 16:51 #59298
by newbynobi
Replied by newbynobi on topic Custom GUI and PyVCP
Steve,
what custom GUI do you use?
Just check the code of gscreen or gmoccapy to see, how we do include panel.
Norbert
Norbert
02 Jun 2015 05:14 #59322
Replied by cmorley on topic Custom GUI and PyVCP
AXIS uses the same widget toolkit as pyVCP (so can natively embedded)
I would bet your custom GUI is GTK based.
Unfortunately IFAIK pyVCP cannot be embedded into GTK based screens.
gladeVCP panels can be embedded.
can you build your pyVCP panel with gladeVCP?
Chris M
Chris M
02 Jun 2015 14:33 #59334
by sdfzz
Replied by sdfzz on topic Custom GUI and PyVCP
Hi, Chris, Norbert,
Thank you for replies. Indeed, my GUI is GTK-based, so I guess it cannot include pyVCP panel...
I will work out a way to run my CNC without using pyVCP..
Regards,
Steve
Regards,
Steve
02 Jun 2015 23:13 #59350
Once you have tried GladeVC you probably won't want to use PyVCP.
Replied by andypugh on topic Custom GUI and PyVCP
03 Jun 2015 05:28 #59360
by BigJohnT
Replied by BigJohnT on topic Custom GUI and PyVCP
13 Jun 2015 01:10 #59753
by vre
Replied by vre on topic Custom GUI and PyVCP
i have a pyvcp custom panel (for huanyang vfd) to the right side of axis gui.
How can move this pyvcp panel to an axis tab like dro tab/ngcgui tabs ?
13 Jun 2015 01:24 - 13 Jun 2015 01:25 #59754
You could try doing the same thing:
www.linuxcnc.org/docs/html/gui/gladevcp....t_to_dro_and_preview
The Command would be something like "halcmd loadusr pyvcp -c mypanel mypanel.xml"
I don't know if it works.
Last edit: 13 Jun 2015 01:25 by andypugh.
13 Jun 2015 03:44 #59765
by vre
with this in my .ini file
Creates a new empty tab "Huanyang" and the panel opens in a new window...
[DISPLAY]
EMBED_TAB_NAME=Huanyang
EMBED_TAB_COMMAND=halcmd loadusr pyvcp -c custompanel custompanel.xml
13 Jun 2015 03:50 #59768
Well, it's a start. Clearly you need a different "command". I don't actually know if this will _ever_ work, but there might be other command-line parameters in the PyVCP docs that give further clues.
Time to create page: 0.106 seconds
