Any used a Mac for development?
- racedirector
- Thank you received: 41
25 Aug 2015 18:14 #61780
by racedirector
Any used a Mac for development? was created by racedirector
A question has been been on my mind and that is has anyone developed a GUI on a Mac. I found Glade available for my Yosemite install but my problem is how to get the LinuxCNC glade components onto the mac to use in the development. SO I am here asking the question
08 Sep 2015 18:08 #62240
Replied by andypugh on topic Any used a Mac for development?
I do all my LinuxCNC development sat at a Mac, though I use a combination of virtual machines and real headless Linux machines on the network for running actual code.
(I use Eclipse and keep the git repository on my Mac, the other machine NFS-mount the git repository and compile locally)
A glade file created on the Mac ought to work in Linux. You might need to change the end-of-line character.
The following user(s) said Thank You: racedirector
- racedirector
08 Sep 2015 18:49 #62246
by racedirector
Replied by racedirector on topic Any used a Mac for development?
Thanks Andy, I will try it then. I currently have virtualbox running on my Mac but Glade keeps crapping out on that which is frustrating. I even have the virtual machine with half of my memory allocated (16GB total) and it makes no diifference.
08 Sep 2015 18:52 #62248
I use VMWare Fusion, and run actual realtime kernels (with _horrible_ latency). It might be worth a look, though it does cost money.
- racedirector
08 Sep 2015 19:45 #62263
by racedirector
I have downloaded and installed Fusion Pro 8 for a 30 day trial. If it works out better than Virtualbox I'll shell out the dollars to buy it
09 Sep 2015 06:38 #62293
by phillc54
Replied by phillc54 on topic Any used a Mac for development?
It may be a Glade feature rather than a Virtualbox issue.
I find that Glade on my Mac/Virtualbox machine dies less often than my Linux/Virtualbox or real Linux machines.
<www.linuxcnc.org/index.php/english/forum...ithout-warning#61910>
Time to create page: 0.138 seconds
