Change from axis to gmoccapy
10 Sep 2015 02:57 - 10 Sep 2015 04:41 #62344 by vre
vre created the topic: Change from axis to gmoccapy
I have a working cnc setup with stepconf wizard but i want to change from axis to gmoccapy.
Is there a tutorial what config changes needed to make gmoccapy work ?
Last Edit: 10 Sep 2015 04:41 by vre.
10 Sep 2015 05:16 #62356 by BigJohnT
BigJohnT replied the topic: Change from axis to gmoccapy
The Gmoccapy chapter in the manual.
JT
10 Sep 2015 05:17 #62357 by cncbasher
cncbasher replied the topic: Change from axis to gmoccapy
just about change the ini file from axis to gmocappy should do
other than minimal changes in your ini file , see examples in sim for gmacoppy and amend as appropratly
if you feel your not up to it post your config as an archive here , and i'll do the required changes if it helps
11 Sep 2015 00:33 #62408 by vre
vre replied the topic: Change from axis to gmoccapy
Here is my config...
If i change from axis to gmocappy it doesn't start
File Name: 6040-paral...9-10.zip
File Size:7 KB
11 Sep 2015 01:08 #62411 by cncbasher
the archive you posted appears to be damaged , could you please check and upload again
extracting the files gives error
11 Sep 2015 05:07 - 11 Sep 2015 05:08 #62426 by vre
I have downloaded and seems ok to me exracting it with winrar.
File Name: 6040-paral...10-2.zip
File Size:7 KB
Last Edit: 11 Sep 2015 05:08 by vre.
11 Sep 2015 16:21 #62439 by cncbasher
this archive is still damaged please use tar gz archives , not windows archivers , they corrupt , passing files between linux and windows is fraught with problems
as the files are converted to windows cr/lf in some cases , use archiver in linux , and then pass the produced archive file to windows if needed , this preserves the files and their permissions .
12 Sep 2015 02:14 - 12 Sep 2015 02:14 #62477 by vre
ok i converted to tar.gz
File Name: 6040-parallel.tar.gz
File Size:6 KB
Last Edit: 12 Sep 2015 02:14 by vre.
14 Sep 2015 18:38 - 14 Sep 2015 19:52 #62556 by cncbasher
thanks
update ;
iv'e got most of the conversion completed
although the vfd is going to need some work , and is where most of the conversion problems occour
Last Edit: 14 Sep 2015 19:52 by cncbasher.
The following user(s) said Thank You: vre
25 Jun 2016 17:11 #76654 by vre
cncbasher wrote: thanks
update ;
can you send me please without vfd ?
Time to create page: 0.119 seconds
