hazzy - Another touchscreen GUI
- Mike_Eitel
- Thank you received: 185
01 May 2017 06:09 #92408
by Mike_Eitel
Replied by Mike_Eitel on topic hazzy - Control Panel
I had very negative experiences with that fellow.
Support was lausy.
Bought bbb extention plus 10"lcd. Not running since then.
Support was lausy.
01 May 2017 08:37 #92413
by TurBoss
Thanks for the info
Replied by TurBoss on topic hazzy - Control Panel
Thanks for the info
15 May 2017 18:08 #93229
by grijalvap
Replied by grijalvap on topic hazzy - Control Panel
Hi
There is any update regarding hazzy.
16 May 2017 16:03 #93268
by KCJ
Replied by KCJ on topic hazzy - Another touchscreen GUI
Since my last post here we have made several significant changes and improvements to hazzy.
The interface is still far from complete, but it is functional and progressing well, thanks to a bunch of help from TurBoss!
Kurt
- The file chooser has been replaced with a full featured file manager. Supports all standard file and folder actions such as cut, copy, paste, rename, new file/folder, move to trash, save as, etc. all in a touchscreen friendly interface.
- The code has been rearranged to make it more flexible and modular. This is in preparation for adding support for user customizeable display panels and notebook tabs
- Several of the components such as the file manager, touchpads and dialogues have been made into stand alone modules so they can easily be used with custom panels
Kurt
The following user(s) said Thank You: tommylight, grijalvap
- Thank you received: 5922
16 May 2017 17:09 #93271
Replied by tommylight on topic hazzy - Another touchscreen GUI
May be asking to much, but the posibility to change the color would be nice.
I like everything black so the color you chose is very well suited for me, but it would give others the posibility to make it more personal.
Thank you,
Tom
Thank you,
Tom
16 May 2017 18:03 #93274
by grijalvap
Replied by grijalvap on topic hazzy - Another touchscreen GUI
Thanks, I will check it this night.
great work
great work
16 May 2017 23:26 #93285
by KCJ
Tom, I have been thinking about how best to make hazzy's appearance customizeable. The button appearances and a few other things can be modified by changing the GTK theme, but the GUI's background is made up of images so it will not change with the theme. I thought about maybe including three or four sets of images with different colors, but that gets cumbersome. I guess since all the images are inkscape SVG's is would be fairly easy for the user to just change the images, but I don't like that as it is not very convenient to have to change each image. I might be able to change the colors of the SVGs from code though, I will have to see about that.
Maybe the best solution is just to chose colors and hope everyone likes it well enough
Thanks Tommy!
Kurt
Thanks Tommy!
Kurt
16 May 2017 23:38 #93286
You are welcomed.
16 May 2017 23:46 #93287
by TurBoss
Replied by TurBoss on topic hazzy - Another touchscreen GUI
what about a ccs stylesheed?
does pygtk support this?
I already worked with great result in gtk3 but not in gtk2
The following user(s) said Thank You: KCJ
- massimodamassa
- Thank you received: 9
22 Jun 2017 08:39 #94781
by massimodamassa
Replied by massimodamassa on topic hazzy - Another touchscreen GUI
Congratulations, very nice this GUI, also works in lathe mode?
Time to create page: 0.168 seconds
