panelui error
05 Jul 2020 20:22 #173688
by roland
panelui error was created by roland
I would like to use panelui. linuxcnc.org/docs/devel/html/gui/panelui.html
But already the start of the demo fails.
What am I doing wrong?
Linuxcnc 2.9, Debian 9
Roland
Roland
05 Jul 2020 20:49 #173689
Replied by cmorley on topic panelui error
The sim works from a RIP development environment.
I'll test an installed version soon.
Chris
Chris
06 Jul 2020 05:07 #173708
I tried on debian and it worked for me...
Can you tell me more about your system and how did you get linuxcnc on it?
- Thank you received: 5944
06 Jul 2020 08:11 #173726
Replied by tommylight on topic panelui error
From the error report:
ImportError: No module named pyui
Twice.
It should be in :
cnc@shop:~$ whereis pyui
pyui: /usr/bin/pyui
It is not a stand alone package, so i do not know what to install to get it.
Twice.
It should be in :
pyui: /usr/bin/pyui
06 Jul 2020 08:19 - 06 Jul 2020 08:20 #173730
by roland
Replied by roland on topic panelui error
i have installed debian stretch using this iso:
cdimage.debian.org/cdimage/archive/9.12.....0-amd64-netinst.iso
I installed LinuxCNC following these instructions:
buildbot.linuxcnc.org/
These are the sources:
deb buildbot.linuxcnc.org/ stretch master-rtpreempt
deb-src buildbot.linuxcnc.org/ stretch master-rtpreempt
sudo apt-get install linuxcnc-uspace
sudo apt-get install linuxcnc-uspace-dev
Everything ist up-to-date
I tested it on two machines:
One is a virtual machine (VirtualBox). See linuxcnc.error in first post.
The other on is my real machine. Same result. See linuxcnc.error attached this post.
Last edit: 06 Jul 2020 08:20 by roland.
06 Jul 2020 09:01 #173737
That is a Python issue, not a LinuxCNC issue.
That should be packaged with something Python related
Some info here, a bit outdated, but might give a clue
ubuntuforums.org/showthread.php?t=29969&...7e806f0a4ab1d5cb9ba4
06 Jul 2020 13:21 - 06 Jul 2020 13:25 #173757
by roland
i tried LinuxCNC 2.8 in a virtual machine: sim starts without error.
I compared the files:
/usr/lib/python2.7/dist-packages/pyui/__init__.py and /usr/lib/python2.7/dist-packages/pyui/master.py between 2.8 and 2.9
and found some differences.
__init__.py 2.8:__init__.py 2.9:
master.py 2.8:
master.py 2.9:
i changed the entries .pyui to pyui and now i can start the sim in 2.9
__init__.py 2.8:
from pyui import master
from .pyui import master
master.py 2.8:
from pyui import widgets as WIDGETS
from pyui import commands
master.py 2.9:
from .pyui import widgets as WIDGETS
from .pyui import commands
Last edit: 06 Jul 2020 13:25 by roland.
07 Jul 2020 01:38 #173801
ok that's weird ! I'm glad you found a work around.
09 Jul 2020 18:37 #174117
by roland
Unfortunately this work around only works until the next apt-get upgrade
I hope this will be fixed in the master sometime
09 Jul 2020 23:48 #174160
I see the change to .pyui was made durin the python3 transition.
I'm not sure why it was done. I'll inquire.
Chris
Chris
The following user(s) said Thank You: roland
Time to create page: 0.430 seconds
