Help in GUI
09 Sep 2010 01:59 #4065
by aike
Help in GUI was created by aike
Hi!
I want to connect emc2 to external controller. This controller wiil have only 4-5 buttoms (start, stop, run, left, right).
The computer will be switched on without display. How can I start emc without GUI? Is it possible?
The conection between emc2 and external controller will be via Mesa5i20 in/out pins.
May be amybody did it so? Can you help me in advice?
09 Sep 2010 09:54 #4072
Replied by andypugh on topic Re:Help in GUI
If the display is not turned on or fitted, does it matter if there is a GUI or not?
You should be able to wire all the necessary GUI buttons to physical buttons if you load halui.
linuxcnc.org/docs/html/gui_halui.html
You might find that if you delete the line in the INI file that refers to AXIS that no GUI is loaded, I am not entirely sure.
linuxcnc.org/docs/2.2/html/config_ini_co...5BDISPLAY%5D-Section
