combine axis and touchy
- barhoumist
25 Jan 2011 14:56 #6836
by barhoumist
combine axis and touchy was created by barhoumist
Hello,
Is there a way to use both GUIs axis and touchy at the same time? I want to have touchy on a touch screen and axis on a normal screen.
Thanks!
Barhoumist
Thanks!
Barhoumist
- barhoumist
25 Jan 2011 16:57 - 25 Jan 2011 16:58 #6837
by barhoumist
Replied by barhoumist on topic Re:combine axis and touchy
I found a way to do it. I moved the needed files from the emc-dev directory so i get those files in my directory:
custom_postgui.hal tool.tbl
custom.hal emc.var
Meine-Maschine.hal touchy
custompanel.xml emc.var.bak
Meine-Maschine.ini touchy.hal
and those in the directory touchy:
hal_interface.pyc mdi.pyc touchy.hal
emc_interface.py lib preferences.py
emc_interface.pyc listing.py preferences.pyc touchy.py
filechooser.py listing.pyc Submakefile
filechooser.pyc locale touchy.glade
hal_interface.py mdi.py
folders locale was located in emc-dev/share and file touchy.glade was located in emc-dev/share/emc
Than I made a few changes in touchy.py:
Than I added this line to hal post gui:
loadusr touchy/touchy.py
And now all in working fine.
I hope this could help somebody
Cheers
Barhoumist
custom.hal emc.var
#!/usr/bin/env python
# Touchy is Copyright (c) 2009 Chris Radek <chris@timeguy.com>
# Touchy is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 2 of the License, or
# (at your option) any later version.
# Touchy is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
import sys, os
#SYSARG0 = "/home/myhome/emc2-dev/"
#SYSARG1 = "-ini"
INI_FILE = "Meine-Maschine.ini"
#BASE = os.path.abspath(os.path.join(os.path.dirname(sys.argv[0]), ".."))
#BASE = os.path.abspath(os.path.join(os.path.dirname(SYSARG0)))
#libdir = os.path.join(BASE, "lib", "python")
#datadir = os.path.join(BASE, "share", "emc")
sys.path.insert(0, "lib")
try:
import pygtk
pygtk.require("2.0")
except:
pass
try:
import gtk
import gtk.glade
import gobject
import pango
except:
sys.exit(1)
import atexit
import tempfile
empty_program = tempfile.NamedTemporaryFile()
empty_program.write("%\n%\n")
empty_program.flush()
import gettext
LOCALEDIR = os.path.join("locale")
gettext.install("emc2", localedir=LOCALEDIR, unicode=True)
gtk.glade.bindtextdomain("emc2", LOCALEDIR)
gtk.glade.textdomain("emc2")
def set_active(w, s):
if not w: return
os = w.get_active()
if os != s: w.set_active(s)
def set_label(w, l):
if not w: return
ol = w.get_label()
if ol != l: w.set_label(l)
def set_text(w, t):
if not w: return
ot = w.get_label()
if ot != t: w.set_label(t)
import emc
import emc_interface
import mdi
import hal_interface
import filechooser
import listing
import preferences
pix_data = '''/* XPM */
static char * invisible_xpm[] = {
"1 1 1 1",
" c None",
color = gtk.gdk.Color()
pix = gtk.gdk.pixmap_create_from_data(None, pix_data, 1, 1, 1, color, color)
invisible = gtk.gdk.Cursor(pix, pix, color, color, 0, 0)
class touchy:
def __init__(self, inifile):
#Set the Glade file
self.gladefile = os.path.join("touchy", "touchy.glade")
self.wTree = gtk.glade.XML(self.gladefile)
for widget in self.wTree.get_widget_prefix(''):
widget.unset_flags(gtk.CAN_FOCUS)
self.wTree.get_widget('MainWindow').set_flags(gtk.CAN_FOCUS)
self.wTree.get_widget('MainWindow').grab_focus()
self.num_mdi_labels = 11
self.num_filechooser_labels = 11
self.num_listing_labels = 20
self.wheelxyz = 0
self.wheelinc = 0
self.wheel = "fo"
self.radiobutton_mask = 0
self.resized_wheelbuttons = 0
self.tab = 0
self.fo_val = 100
self.so_val = 100
self.g10l11 = 0
self.prefs = preferences.preferences()
self.mv_val = self.prefs.getpref('maxvel', 100, int)
self.control_font_name = self.prefs.getpref('control_font', 'Sans 18', str)
self.dro_font_name = self.prefs.getpref('dro_font', 'Courier 10 Pitch Bold 16', str)
self.error_font_name = self.prefs.getpref('error_font', 'Sans Bold 10', str)
self.listing_font_name = self.prefs.getpref('listing_font', 'Sans 10', str)
# initial screen setup
self.invisible_cursor = self.prefs.getpref('invisible_cursor', 0)
if self.invisible_cursor:
self.wTree.get_widget("MainWindow").window.set_cursor(invisible)
else:
self.wTree.get_widget("MainWindow").window.set_cursor(None)
self.wTree.get_widget("controlfontbutton").set_font_name(self.control_font_name)
self.control_font = pango.FontDescription(self.control_font_name)
self.wTree.get_widget("drofontbutton").set_font_name(self.dro_font_name)
self.dro_font = pango.FontDescription(self.dro_font_name)
self.wTree.get_widget("errorfontbutton").set_font_name(self.error_font_name)
self.error_font = pango.FontDescription(self.error_font_name)
self.wTree.get_widget("listingfontbutton").set_font_name(self.listing_font_name)
self.listing_font = pango.FontDescription(self.listing_font_name)
# interactive mdi command builder and issuer
mdi_labels = []
mdi_eventboxes = []
for i in range(self.num_mdi_labels):
mdi_labels.append(self.wTree.get_widget("mdi%d" % i))
mdi_eventboxes.append(self.wTree.get_widget("eventbox_mdi%d" % i))
self.mdi_control = mdi.mdi_control(gtk, emc, mdi_labels, mdi_eventboxes)
if inifile:
ini = emc.ini(inifile)
self.mdi_control.mdi.add_macros(
ini.findall("TOUCHY", "MACRO"))
self.ini = ini
else:
self.ini = None
listing_labels = []
listing_eventboxes = []
for i in range(self.num_listing_labels):
listing_labels.append(self.wTree.get_widget("listing%d" % i))
listing_eventboxes.append(self.wTree.get_widget("eventbox_listing%d" % i))
self.listing = listing.listing(gtk, emc, listing_labels, listing_eventboxes)
# emc interface
self.emc = emc_interface.emc_control(emc, self.listing, self.wTree.get_widget("error"))
self.hal = hal_interface.hal_interface(self, self.emc, self.mdi_control, emc)
# silly file chooser
filechooser_labels = []
filechooser_eventboxes = []
for i in range(self.num_filechooser_labels):
filechooser_labels.append(self.wTree.get_widget("filechooser%d" % i))
filechooser_eventboxes.append(self.wTree.get_widget("eventbox_filechooser%d" % i))
self.filechooser = filechooser.filechooser(gtk, emc, filechooser_labels, filechooser_eventboxes, self.listing)
relative = ['xr', 'yr', 'zr', 'ar', 'br', 'cr', 'ur', 'vr', 'wr']
absolute = ['xa', 'ya', 'za', 'aa', 'ba', 'ca', 'ua', 'va', 'wa']
distance = ['xd', 'yd', 'zd', 'ad', 'bd', 'cd', 'ud', 'vd', 'wd']
relative = [self.wTree.get_widget(i) for i in relative]
absolute = [self.wTree.get_widget(i) for i in absolute]
distance = [self.wTree.get_widget(i) for i in distance]
estops = ['estop_reset', 'estop']
estops = dict((i, self.wTree.get_widget(i)) for i in estops)
machines = ['on', 'off']
machines = dict((i, self.wTree.get_widget("machine_" + i)) for i in machines)
floods = ['on', 'off']
floods = dict((i, self.wTree.get_widget("flood_" + i)) for i in floods)
mists = ['on', 'off']
mists = dict((i, self.wTree.get_widget("mist_" + i)) for i in mists)
spindles = ['forward', 'off', 'reverse']
spindles = dict((i, self.wTree.get_widget("spindle_" + i)) for i in spindles)
stats = ['file', 'file_lines', 'line', 'id', 'dtg', 'velocity', 'delay', 'onlimit',
'spindledir', 'spindlespeed', 'loadedtool', 'preppedtool',
'xyrotation', 'tlo', 'activecodes', 'spindlespeed2',
'label_g5xoffset', 'g5xoffset', 'g92offset', 'tooltable']
stats = dict((i, self.wTree.get_widget("status_" + i)) for i in stats)
prefs = ['actual', 'commanded', 'inch', 'mm']
prefs = dict((i, self.wTree.get_widget("dro_" + i)) for i in prefs)
opstop = ['on', 'off']
opstop = dict((i, self.wTree.get_widget("opstop_" + i)) for i in opstop)
blockdel = ['on', 'off']
blockdel = dict((i, self.wTree.get_widget("blockdel_" + i)) for i in blockdel)
self.status = emc_interface.emc_status(gtk, emc, self.listing, relative, absolute, distance,
self.wTree.get_widget("dro_table"),
self.wTree.get_widget("error"),
estops, machines,
self.wTree.get_widget("override_limits"),
stats,
floods, mists, spindles, prefs,
opstop, blockdel)
# check the ini file if UNITS are set to mm"
inifile=self.emc.emc.ini(INI_FILE)
# first check the global settings
units=inifile.find("TRAJ","LINEAR_UNITS")
if units==None:
units=inifile.find("AXIS_0","UNITS")
if units=="mm" or units=="metric" or units == "1.0":
self.machine_units_mm=1
conversion=[1.0/25.4]*3+[1]*3+[1.0/25.4]*3
else:
self.machine_units_mm=0
conversion=[25.4]*3+[1]*3+[25.4]*3
self.status.set_machine_units(self.machine_units_mm,conversion)
if self.prefs.getpref('toolsetting_fixture', 0):
self.g10l11 = 1
else:
self.g10l11 = 0
if self.prefs.getpref('dro_mm', 0):
self.status.dro_mm(0)
else:
self.status.dro_inch(0)
if self.prefs.getpref('dro_actual', 0):
self.status.dro_actual(0)
else:
self.status.dro_commanded(0)
if self.prefs.getpref('blockdel', 0):
self.emc.blockdel_on(0)
else:
self.emc.blockdel_off(0)
if self.prefs.getpref('opstop', 1):
self.emc.opstop_on(0)
else:
self.emc.opstop_off(0)
self.emc.emccommand.program_open(empty_program.name)
self.emc.max_velocity(self.mv_val)
gobject.timeout_add(50, self.periodic_status)
gobject.timeout_add(100, self.periodic_radiobuttons)
# event bindings
dic = {
"quit" : self.quit,
"on_pointer_show_clicked" : self.pointer_show,
"on_pointer_hide_clicked" : self.pointer_hide,
"on_opstop_on_clicked" : self.opstop_on,
"on_opstop_off_clicked" : self.opstop_off,
"on_blockdel_on_clicked" : self.blockdel_on,
"on_blockdel_off_clicked" : self.blockdel_off,
"on_reload_tooltable_clicked" : self.emc.reload_tooltable,
"on_notebook1_switch_page" : self.tabselect,
"on_controlfontbutton_font_set" : self.change_control_font,
"on_drofontbutton_font_set" : self.change_dro_font,
"on_dro_actual_clicked" : self.dro_actual,
"on_dro_commanded_clicked" : self.dro_commanded,
"on_dro_inch_clicked" : self.dro_inch,
"on_dro_mm_clicked" : self.dro_mm,
"on_errorfontbutton_font_set" : self.change_error_font,
"on_listingfontbutton_font_set" : self.change_listing_font,
"on_estop_clicked" : self.emc.estop,
"on_estop_reset_clicked" : self.emc.estop_reset,
"on_machine_off_clicked" : self.emc.machine_off,
"on_machine_on_clicked" : self.emc.machine_on,
"on_mdi_clear_clicked" : self.mdi_control.clear,
"on_mdi_back_clicked" : self.mdi_control.back,
"on_mdi_next_clicked" : self.mdi_control.next,
"on_mdi_decimal_clicked" : self.mdi_control.decimal,
"on_mdi_minus_clicked" : self.mdi_control.minus,
"on_mdi_keypad_clicked" : self.mdi_control.keypad,
"on_mdi_g_clicked" : self.mdi_control.g,
"on_mdi_gp_clicked" : self.mdi_control.gp,
"on_mdi_m_clicked" : self.mdi_control.m,
"on_mdi_t_clicked" : self.mdi_control.t,
"on_mdi_select" : self.mdi_control.select,
"on_mdi_set_tool_clicked" : self.mdi_set_tool,
"on_mdi_set_origin_clicked" : self.mdi_set_origin,
"on_mdi_macro_clicked" : self.mdi_macro,
"on_filechooser_select" : self.fileselect,
"on_filechooser_up_clicked" : self.filechooser.up,
"on_filechooser_down_clicked" : self.filechooser.down,
"on_filechooser_reload_clicked" : self.filechooser.reload,
"on_listing_up_clicked" : self.listing.up,
"on_listing_down_clicked" : self.listing.down,
"on_listing_previous_clicked" : self.listing.previous,
"on_listing_next_clicked" : self.listing.next,
"on_mist_on_clicked" : self.emc.mist_on,
"on_mist_off_clicked" : self.emc.mist_off,
"on_flood_on_clicked" : self.emc.flood_on,
"on_flood_off_clicked" : self.emc.flood_off,
"on_home_all_clicked" : self.emc.home_all,
"on_unhome_all_clicked" : self.emc.unhome_all,
"on_home_selected_clicked" : self.home_selected,
"on_unhome_selected_clicked" : self.unhome_selected,
"on_fo_clicked" : self.fo,
"on_so_clicked" : self.so,
"on_mv_clicked" : self.mv,
"on_jogging_clicked" : self.jogging,
"on_wheelx_clicked" : self.wheelx,
"on_wheely_clicked" : self.wheely,
"on_wheelz_clicked" : self.wheelz,
"on_wheela_clicked" : self.wheela,
"on_wheelb_clicked" : self.wheelb,
"on_wheelc_clicked" : self.wheelc,
"on_wheelu_clicked" : self.wheelu,
"on_wheelv_clicked" : self.wheelv,
"on_wheelw_clicked" : self.wheelw,
"on_wheelinc1_clicked" : self.wheelinc1,
"on_wheelinc2_clicked" : self.wheelinc2,
"on_wheelinc3_clicked" : self.wheelinc3,
"on_override_limits_clicked" : self.emc.override_limits,
"on_spindle_forward_clicked" : self.emc.spindle_forward,
"on_spindle_off_clicked" : self.emc.spindle_off,
"on_spindle_reverse_clicked" : self.emc.spindle_reverse,
"on_spindle_slower_clicked" : self.emc.spindle_slower,
"on_spindle_faster_clicked" : self.emc.spindle_faster,
"on_toolset_fixture_clicked" : self.toolset_fixture,
"on_toolset_workpiece_clicked" : self.toolset_workpiece,
self.wTree.signal_autoconnect(dic)
if isinstance(widget, gtk.Button):
widget.connect_after('released',self.hack_leave)
self._dynamic_childs = {}
atexit.register(self.kill_dynamic_childs)
self.set_dynamic_tabs()
self.setfont()
def quit(self, unused):
gtk.main_quit()
def tabselect(self, notebook, b, tab):
self.tab = tab
def pointer_hide(self, b):
if self.radiobutton_mask: return
self.prefs.putpref('invisible_cursor', 1)
self.invisible_cursor = 1
def pointer_show(self, b):
self.prefs.putpref('invisible_cursor', 0)
self.invisible_cursor = 0
def dro_commanded(self, b):
self.prefs.putpref('dro_actual', 0)
self.status.dro_commanded(b)
def dro_actual(self, b):
self.prefs.putpref('dro_actual', 1)
self.status.dro_actual(b)
def dro_inch(self, b):
self.prefs.putpref('dro_mm', 0)
self.status.dro_inch(b)
def dro_mm(self, b):
self.prefs.putpref('dro_mm', 1)
self.status.dro_mm(b)
def opstop_on(self, b):
self.prefs.putpref('opstop', 1)
self.emc.opstop_on(b)
def opstop_off(self, b):
self.prefs.putpref('opstop', 0)
self.emc.opstop_off(b)
def blockdel_on(self, b):
self.prefs.putpref('blockdel', 1)
self.emc.blockdel_on(b)
def blockdel_off(self, b):
self.prefs.putpref('blockdel', 0)
self.emc.blockdel_off(b)
def wheelx(self, b):
self.wheelxyz = 0
def wheely(self, b):
self.wheelxyz = 1
def wheelz(self, b):
self.wheelxyz = 2
def wheela(self, b):
self.wheelxyz = 3
def wheelb(self, b):
self.wheelxyz = 4
def wheelc(self, b):
self.wheelxyz = 5
def wheelu(self, b):
self.wheelxyz = 6
def wheelv(self, b):
self.wheelxyz = 7
def wheelw(self, b):
self.wheelxyz = 8
def wheelinc1(self, b):
self.wheelinc = 0
def home_selected(self, b):
self.emc.home_selected(self.wheelxyz)
def unhome_selected(self, b):
self.emc.unhome_selected(self.wheelxyz)
def wheelinc2(self, b):
self.wheelinc = 1
def wheelinc3(self, b):
self.wheelinc = 2
def fo(self, b):
self.wheel = "fo"
self.jogsettings_activate(0)
def so(self, b):
self.wheel = "so"
def mv(self, b):
self.wheel = "mv"
def jogging(self, b):
self.wheel = "jogging"
self.emc.jogging(b)
self.jogsettings_activate(1)
def toolset_fixture(self, b):
self.prefs.putpref('toolsetting_fixture', 1)
self.g10l11 = 1
def toolset_workpiece(self, b):
self.prefs.putpref('toolsetting_fixture', 0)
self.g10l11 = 0
def jogsettings_activate(self, active):
for i in ["wheelinc1", "wheelinc2", "wheelinc3"]:
w = self.wTree.get_widget(i)
w.set_sensitive(active)
self.hal.jogactive(active)
def change_control_font(self, fontbutton):
self.control_font_name = fontbutton.get_font_name()
self.prefs.putpref('control_font', self.control_font_name, str)
self.setfont()
def change_dro_font(self, fontbutton):
self.dro_font_name = fontbutton.get_font_name()
self.prefs.putpref('dro_font', self.dro_font_name, str)
self.setfont()
def change_error_font(self, fontbutton):
self.error_font_name = fontbutton.get_font_name()
self.prefs.putpref('error_font', self.error_font_name, str)
self.setfont()
def change_listing_font(self, fontbutton):
self.listing_font_name = fontbutton.get_font_name()
self.prefs.putpref('listing_font', self.listing_font_name, str)
self.setfont()
def setfont(self):
# buttons
for i in ["1", "2", "3", "4", "5", "6", "7",
"8", "9", "0", "minus", "decimal",
"flood_on", "flood_off", "mist_on", "mist_off",
"g", "gp", "m", "t", "set_tool", "set_origin", "macro",
"estop", "estop_reset", "machine_off", "machine_on",
"home_all", "unhome_all", "home_selected", "unhome_selected",
"fo", "so", "mv", "jogging", "wheelinc1", "wheelinc2", "wheelinc3",
"wheelx", "wheely", "wheelz",
"wheela", "wheelb", "wheelc",
"wheelu", "wheelv", "wheelw",
"override_limits",
"spindle_forward", "spindle_off", "spindle_reverse",
"spindle_faster", "spindle_slower",
"dro_commanded", "dro_actual", "dro_inch", "dro_mm",
"reload_tooltable", "opstop_on", "opstop_off",
"blockdel_on", "blockdel_off", "pointer_hide", "pointer_show",
"toolset_workpiece", "toolset_fixture"]:
if w:
w = w.child
w.modify_font(self.control_font)
notebook = self.wTree.get_widget('notebook1')
for i in range(notebook.get_n_pages()):
w = notebook.get_nth_page(i)
notebook.get_tab_label(w).modify_font(self.control_font)
# labels
w = self.wTree.get_widget("mdi%d" % i)
w = self.wTree.get_widget("filechooser%d" % i)
w = self.wTree.get_widget("listing%d" % i)
w.modify_font(self.listing_font)
for i in ["mdi", "startup", "manual", "auto", "preferences", "status",
"relative", "absolute", "dtg", "ss2label", "status_spindlespeed2"]:
# dro
for i in ['xr', 'yr', 'zr', 'ar', 'br', 'cr', 'ur', 'vr', 'wr',
'xa', 'ya', 'za', 'aa', 'ba', 'ca', 'ua', 'va', 'wa',
'xd', 'yd', 'zd', 'ad', 'bd', 'cd', 'ud', 'vd', 'wd']:
if w: w.modify_font(self.dro_font)
# status bar
for i in ["error"]:
w.modify_font(self.error_font)
self.wTree.get_widget("MainWindow").window.maximize()
def mdi_set_tool(self, b):
self.mdi_control.set_tool(self.status.get_current_tool(), self.g10l11)
def mdi_set_origin(self, b):
self.mdi_control.set_origin(self.status.get_current_system())
def mdi_macro(self, b):
self.mdi_control.o(b)
def fileselect(self, eb, e):
if self.wheel == "jogging": self.wheel = "mv"
self.filechooser.select(eb, e)
self.listing.clear_startline()
def periodic_status(self):
self.emc.mask()
self.radiobutton_mask = 1
self.status.periodic()
self.emc.unmask()
self.hal.periodic(self.tab == 1) # MDI tab?
return True
def periodic_radiobuttons(self):
s = emc.stat()
s.poll()
am = s.axis_mask
if not self.resized_wheelbuttons:
at = self.wTree.get_widget("axis_table")
for i in range(9):
b = ["wheelx", "wheely", "wheelz",
"wheelu", "wheelv", "wheelw"][i]
w = self.wTree.get_widget(b)
if not (am & (1<<i)):
at.remove(w)
if (am & 0700) == 0:
at.resize(3, 2)
if (am & 070) == 0:
at.resize(3, 1)
self.wTree.get_widget("wheel_hbox").set_homogeneous(1)
self.resized_wheelbuttons = 1
set_active(self.wTree.get_widget("wheelx"), self.wheelxyz == 0)
set_active(self.wTree.get_widget("wheely"), self.wheelxyz == 1)
set_active(self.wTree.get_widget("wheelz"), self.wheelxyz == 2)
set_active(self.wTree.get_widget("wheela"), self.wheelxyz == 3)
set_active(self.wTree.get_widget("wheelb"), self.wheelxyz == 4)
set_active(self.wTree.get_widget("wheelc"), self.wheelxyz == 5)
set_active(self.wTree.get_widget("wheelu"), self.wheelxyz == 6)
set_active(self.wTree.get_widget("wheelv"), self.wheelxyz == 7)
set_active(self.wTree.get_widget("wheelw"), self.wheelxyz == 8)
set_active(self.wTree.get_widget("wheelinc1"), self.wheelinc == 0)
set_active(self.wTree.get_widget("wheelinc2"), self.wheelinc == 1)
set_active(self.wTree.get_widget("wheelinc3"), self.wheelinc == 2)
set_active(self.wTree.get_widget("fo"), self.wheel == "fo")
set_active(self.wTree.get_widget("so"), self.wheel == "so")
set_active(self.wTree.get_widget("mv"), self.wheel == "mv")
set_active(self.wTree.get_widget("jogging"), self.wheel == "jogging")
set_active(self.wTree.get_widget("pointer_show"), not self.invisible_cursor)
set_active(self.wTree.get_widget("pointer_hide"), self.invisible_cursor)
set_active(self.wTree.get_widget("toolset_workpiece"), not self.g10l11)
set_active(self.wTree.get_widget("toolset_fixture"), self.g10l11)
self.hal.jogaxis(self.wheelxyz)
else:
# disable all
self.hal.jogaxis(-1)
if self.wheelxyz == 3 or self.wheelxyz == 4 or self.wheelxyz == 5:
incs = ["1.0", "0.1", "0.01"]
elif self.machine_units_mm:
incs = ["0.1", "0.01", "0.001"]
else:
incs = ["0.01", "0.001", "0.0001"]
set_label(self.wTree.get_widget("wheelinc1").child, incs[0])
set_label(self.wTree.get_widget("wheelinc2").child, incs[1])
set_label(self.wTree.get_widget("wheelinc3").child, incs[2])
self.hal.jogincrement(self.wheelinc, map(float,incs))
d = self.hal.wheel()
if self.wheel == "fo":
self.fo_val += d
if self.fo_val < 0: self.fo_val = 0
if d != 0: self.emc.feed_override(self.fo_val)
if self.wheel == "so":
self.so_val += d
if self.so_val < 0: self.so_val = 0
if d != 0: self.emc.spindle_override(self.so_val)
if self.wheel == "mv":
self.mv_val += 20 * d
else:
self.mv_val += d
if self.mv_val < 0: self.mv_val = 0
if d != 0:
self.emc.continuous_jog_velocity(self.mv_val)
self.prefs.putpref('maxvel', self.mv_val, int)
set_label(self.wTree.get_widget("fo").child, "FO: %d%%" % self.fo_val)
set_label(self.wTree.get_widget("so").child, "SO: %d%%" % self.so_val)
set_label(self.wTree.get_widget("mv").child, "MV: %d" % self.mv_val)
return True
def hack_leave(self,w):
if not self.invisible_cursor: return
w = self.wTree.get_widget("MainWindow").window
d = w.get_display()
s = w.get_screen()
x, y = w.get_origin()
d.warp_pointer(s, x, y)
def _dynamic_tab(self, notebook, text):
s = gtk.Socket()
notebook.append_page(s, gtk.Label(" " + text + " "))
return s.get_id()
def set_dynamic_tabs(self):
from subprocess import Popen
if not self.ini:
return
tab_names = self.ini.findall("DISPLAY", "EMBED_TAB_NAME")
tab_cmd = self.ini.findall("DISPLAY", "EMBED_TAB_COMMAND")
if len(tab_names) != len(tab_cmd):
print "Invalid tab configuration" # Complain somehow
nb = self.wTree.get_widget('notebook1')
for t,c in zip(tab_names, tab_cmd):
xid = self._dynamic_tab(nb, t)
if not xid: continue
cmd = c.replace('{XID}', str(xid))
child = Popen(cmd.split())
self._dynamic_childs[xid] = child
nb.show_all()
def kill_dynamic_childs(self):
for c in self._dynamic_childs.values():
c.terminate()
if __name__ == "__main__":
if len(sys.argv) > 2 and sys.argv[1] == '-ini':
print "ini", sys.argv[2]
hwg = touchy(INI_FILE)
else:
# hwg = touchy()
res = os.spawnvp(os.P_WAIT, "halcmd", ["halcmd", "-f", "touchy.hal"])
if res: raise SystemExit, res
gtk.main()
Cheers
Barhoumist
Last edit: 25 Jan 2011 16:58 by barhoumist.
25 Jan 2011 18:00 #6838
by psha
Replied by psha on topic Re:combine axis and touchy
What's problem to load both of them?
Have Axis listed as DISPLAY and touchy as userspace component?
There are no limitations how many GUI's are running - i was easily running both touchy and home baked gui
Time to create page: 0.138 seconds
