Joystick (adding more features)
  • theo-rist
  • theo-rist's Avatar Topic Author
  • Visitor
  • Visitor
17 Jun 2014 01:59 #48012 by theo-rist
Joystick (adding more features) was created by theo-rist
Ein Hallo an die Gemeinde ;)
Brauch Hilfe im Bezug auf die Joystick Steuerung (Part 2, more features)
wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding...imple_Remote_Pendant
Den Ersten einfachen Teil habe ich zum laufen bekommen!
Im zweiten Part taucht was auf wie folgt
halui.mdi-command-05
Es gibt beim starten Fehler! Hier mal Auszüge aus meiner .ini und meiner main.hal
In der .ini
[HAL]
POSTGUI_HALFILE = custom_postgui.hal
HALUI = halui
Und in der Main.hal
# for remote joypad
loadusr -W hal_input -KRAL Thrustmaster
was ist das? halui.mdi-command-XX und was muss da jetzt wo noch hin?
PS: Steuerung soll hinterher auch wider für 3 Achsen sein. So wie im ersten Teil.
Ich freue mich auf eure Anregungen :cheer:
18 Jun 2014 14:54 #48051 by Rick G
mdi command 05 is to play a beep on the computer speaker to let the operator know that the machine is now in incremental jog mode.
#1 use button 4 to switch to incremental jog. #7 use button 4 for stop program run
net button-4 and2.12.in1 and2.18.in0 <= input.0.btn-top
net jog-man-to-inc and2.18.in1 <= not.0.out
net jog-inc halui.mdi-command-05 flipflop.0.set <= and2.18.out
#Uncomment and use the following MDI_COMMANDS in the .ini file in the HALUI section"
#these four set each axis to zero similar to touch off, but using G10 you can change to numbers to reflect the size of #your edge finder these must be in the proper order
#MDI_COMMAND = G10 L20 P1 X-.125 M101
#MDI_COMMAND = G10 L20 P1 Y-.125 M102
#MDI_COMMAND = G10 L20 P1 Z0.000 M103
#MDI_COMMAND = G10 L20 P1 W0.000 M104
#this sets the file to be run for home
#MDI_COMMAND = o<home> call
# #<home> uses M105 for song M111 to erase message
#1 long beep for incremental, song for proportional
### MDI command 05
#MDI_COMMAND = M106
### MDI command 06
#MDI_COMMAND = M107
M106 is a user defined M code...
M106
# beep for incremental
 #! /bin/sh
beep -f 100 -l 200-n
 exit 0
Rick G
Time to create page: 0.057 seconds
