linuxcnc neu installieren...
02 Mar 2015 17:38 #56397 by karlhe
hello,
I need to delete linuxcnc if I still or
want to reinstall? Or is there another way to bring it back clean
to get? My cnc machine can no longer be set correctly ...
Sorry my english is bad..
Thanks for the help
karlhe
02 Mar 2015 19:36 - 02 Mar 2015 21:15 #56401 by ArcEye
Replied by ArcEye on topic linuxcnc neu installieren...
Hi
Because Linux works with configuration files, there is rarely any need to re-install, like you need to with windoze once the registery gets well and truely screwed up.
Describe your actual problem in German and we can see if we can put it through a translator and understand it
Last edit: 02 Mar 2015 21:15 by ArcEye.
02 Mar 2015 22:52 #56407 by karlhe
Replied by karlhe on topic linuxcnc neu installieren...
Hallo arceye,
meine Steuerung war defekt, sie ist wieder repariert, ich kann alle Achsen verfahren. Wenn ich die Home-postion
anfahren moechte, faehrt die z Achse in minus, sie erreicht den Endschalter dadurch nicht.
In der Hal kann ich die Signale auch nicht veraendern.
Die Maschine lief vor dem Defekt einwandfrei. Ich habe keine Erklaerung
Danke für deine Hilfe
karlhe
Mail: This email address is being protected from spambots. You need JavaScript enabled to view it.
03 Mar 2015 00:53 #56409 by ArcEye
my control was broken, it is repaired again, I can all axes. When I use the home postion
Ideally approach, then the z axis in minus, it does not reach the limit switch thereby.
Hal, I can not change in yourself the signals also.
The machine was running before the defect properly. I have no explanation
OK, translation not 100% clear (or even 80%!)
Does the machine home OK but you cannot move to Z- afterwards,
or does it not home properly because it does not move to Z-?
03 Mar 2015 05:49 #56414 by newbynobi
Hallo karlhe,
Wenn ich richtig verstehe, dann fährt die Z Achse vom Homeschalter weg, anstatt zu ihm hin, richtig?
Wenn ja, dann musst du nur in deiner Hal Datei das Borzeichen bei search velocity der z Achse ändern. Fals du auch latch velocity verwendest, dann auch dort das Vorzeichen ändern.
Ggf. Kannst du auch deine gesammte config posten.
Auf jeden Fall, kein Grund für eine Neuinstallation.
Norbert
04 Mar 2015 02:47 #56438 by karlhe
Hallo Norbert,
die von Dir vorgeschlagenen Aenderungen konnte ich nicht finden.
Als Anhang meine config....
Grüße D.heinrich
05 Mar 2015 16:14 #56497 by karlhe
Hallo Norbert,
Grüße D.heinrich
08 Mar 2015 14:07 #56542 by karlhe
Hallo,
ich habe den Fehler gefunden....
Alt
HOME_SEARCH_VEL = 8.000000
HOME_LATCH_VEL = 5.000000
NEU
HOME_SEARCH_VEL =-8.000000
HOME_LATCH_VEL =-5.0000000
Danke
Karl he
09 Mar 2015 04:45 #56553 by newbynobi
Geht doch B)
Time to create page: 0.119 seconds
