Mesa 5i25 custom bitfile
20 Nov 2015 22:00 - 20 Nov 2015 22:08 #65588
by Talla
Mesa 5i25 custom bitfile was created by Talla
Hallo Gemeinde,
ich benutze eine Mesa 5i25 (PROB_RFX2) um 3 Achsen zu steuern.
(Closed Loop mit Stepper und Glasmassstab.)
X und Y funktionieren einwandfrei nur bekomme ich Z nicht zum laufen da die Karte nur 2 Eingänge für Encoder hat.
Ist es möglich ohne Daugtherboard 3 Eingänge für Encoder zu erzeugen? Zum Beispiel durch ein entsprechendes Bitfile ?
Last edit: 20 Nov 2015 22:08 by Talla.
20 Nov 2015 23:47 #65591
Replied by PCW on topic Mesa 5i25 custom bitfile
<q>Hello community ,
I use a Mesa 5i25 ( PROB_RFX2 ) to control 3 axes .
( Closed Loop with Stepper and glass scale . )
X and Y function properly only I get Z not to run because the map only 2 inputs for encoder has .
Is it possible without Daugtherboard 3 inputs to produce for encoder ? For example, by a corresponding bitfile ? </q>
Sure, can you post your desired P3 and P2 pinout here
21 Nov 2015 09:56 - 21 Nov 2015 09:56 #65595
by Talla
Replied by Talla on topic Mesa 5i25 custom bitfile
Hello PCW
currently I have no fixed pinout as I am still trying on .
To test all axes together I need 3 Stepgen and 3 encoder .
The pins should be on P3 .
For example,
01 - step 0
02 - dir 0
03 - step 1
04 - dir 1
05 - step 2
06 - dir 2
07 - A 0
08 - B 0
09 - I 0
10 - A 1
11 - B 1
12 - I 1
13 - A 2
14 - B 2
15 - I 2
thx
For example,
01 - step 0
02 - dir 0
03 - step 1
04 - dir 1
05 - step 2
06 - dir 2
07 - A 0
08 - B 0
09 - I 0
10 - A 1
11 - B 1
12 - I 1
13 - A 2
14 - B 2
15 - I 2
thx
Last edit: 21 Nov 2015 09:56 by Talla.
21 Nov 2015 13:13 #65599
by Talla
Hello.
When I try it myself I get from ISE 2 Error. But i change nothing! Whats wrong?
Version 14.7
Version 14.7
21 Nov 2015 16:01 #65610
Not sure why you have that error
I just tried compiling from the sources and didn't find an issue
are you using the fivei25.xise project file and the latest hostmot2.zip?
MD5 (hostmot2.zip) = 537d9e74c60b1d0864163f0b75eab74d
21 Nov 2015 16:21 - 21 Nov 2015 17:35 #65612
by cncbasher
Replied by cncbasher on topic Mesa 5i25 custom bitfile
the error is that the files cannot be found
Last edit: 21 Nov 2015 17:35 by cncbasher.
21 Nov 2015 16:45 #65613
Actually only the hostmot2.zip file needs to be unzipped
the other zip files:
etherhm2.zip
resmod.zip
sslbp.zip
twiddler.zip
serhm2.zip
ssremote.zip
Are all sources for machine language code that goes in various processor ROM VHDL files
They are provided for reference but are not needed (or usable) by ISE
etherhm2.zip
resmod.zip
sslbp.zip
twiddler.zip
serhm2.zip
ssremote.zip
21 Nov 2015 18:10 #65614
by Talla
Ok i try it with the actually files.
21 Nov 2015 20:03 #65617
by Talla
Surprise ! It works!
Many thanks for your help.
21 Nov 2015 20:24 #65620
by cncbasher
Talla,
Did you have to do any other changes in ise 14.7 ? , i have just moved from ise 13.1 and having problems that the map will not
compile and errors .
