pyvcp et bouton déplacement
18 Feb 2013 05:37 #30231 by finemeca
Bonjour,
J'ai un panneau pyvcp comme indiqué ici :
wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding_Custom_MDI_Buttons
Mais je souhaite que le bouton puisse faire avancer l'axe d'une certaine quantité.
par exemple 1mm, 0.5mm, 0.1mm et 0.1mm
J'ai trouvé ce post : www.linuxcnc.org/index.php/french/forum/...alui-incremental-jog
Mais comment faire pour lier l'ensemble à mon panneau pvycp ?
Pierre
18 Feb 2013 17:52 #30271 by ArcEye
Replied by ArcEye on topic pyvcp et bouton déplacement
Hi
First of all, you can move your axes incrementally from Axis, click on the drop down combo box under the axis radio buttons and change 'Continuous' to the required distance.
If you don't like the increments you can change them in the .ini file
[DISPLAY]
INCREMENTS = 5mm 1mm 0.1mm 0.01mm for instance
If you want to duplicate this, or implement it another way, you will need to do some reading.
The wiki you quoted - wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding_Custom_MDI_Buttons
shows you how to implement buttons and link them to halui pins in a postgui.hal file (albeit the MDI command ones)
linuxcnc.org/docs/2.5/html/gui/halui.html
shows you all the halui pins and parameters
and the lesson from this post is that you have to set a jog speed or the axes will not move.
( which is far from clear, reading the pin descriptions you might think it only required if using continuous jog plus and minus )
So create a panel with buttons which relate to functions provided by the halui.jog- pins that you wish to use, and link them to those pins in the postgui.hal file as demonstrated in the wiki
19 Feb 2013 14:52 - 19 Feb 2013 14:53 #30310 by finemeca
Bonsoir ArcEye,
Merci de t'intéresser à mon problème :)
Alors, dans custompanel.xml, je fais un bouton :
  <!-- le bouton choix vitesse -->
        <radiobutton>
            <choices>["Lent","Rapide"]</choices>
            <halpin>"jog-speed"</halpin>
        </radiobutton>
 <!-- le bouton quantite deplacement -->
 	<radiobutton>
            <choices>["5.0","1.0","0.5","0.1","0.01"]</choices>
            <halpin>"jog-deplacement"</halpin>
        </radiobutton>
 <!-- le bouton de jog de l'axe X -->
        <hbox>
            <relief>RAISED</relief>
            <button>
                <font>("Helvetica",12)</font>
                <width>4</width>
                <halpin>"x-moins"</halpin>
                <text>"X-"</text>
            </button>
            <button>
                <width>4</width>
                <halpin>"x-plus"</halpin>
                <text>"X+"</text>
            </button>
        </hbox>
Mais mon problème est de lier mon bouton à halui
Dans la doc, il est écrit :
halui.jog.<n>.minus (bit, in) - jog en direction négative
Ce qui donne :
net my-jogxmoins halui.jog.0.minus <= pyvcp.x-moins
Mais je ne trouve rien sur la quantité de déplacement, par exemple pour faire avancer de 1mm l'axe X dans la direction négative.
Est-ce possible ?
Last edit: 19 Feb 2013 14:53 by finemeca.
19 Feb 2013 18:00 #30313 by ArcEye
Hi
Ce qui donne :
Est-ce possible ?
If you study the documentation (linuxcnc.org/docs/2.5/html/gui/halui.html)
you will see that there are 2 different jog methods catered for
halui.jog.<n>.minus and halui.jog.<n>.plus are for continuous jogs at the speed entered in halui.jog-speed
If you want an incremental jog, you need to set halui.jog.<n>.increment to the increment figure you want
then use halui.jog.<n>.increment-minus or halui.jog.<n>.increment-plus to move the axis
Don't forget the thread you found www.linuxcnc.org/index.php/french/forum/...alui-incremental-jog
You will need to set a default figure for halui.jog-speed, even though you are not using continuous mode.
That will set the speed at which the axis moves, albeit only for a very short distance.
Unless set, it will not move.
Using your example (which I have not tested)
something similar to
setp halui.jog-speed 300
setp halui.jog.0.increment 1.00
net my-jogxmoins halui.jog.0.increment-minus <= pyvcp.x-moins
net my-jogxplus halui.jog.0.increment-plus <= pyvcp.x-plus
You can make it even simpler and use the halui.jog.selected.increment-?? pins and your jog actions will work with whichever axis is currently selected
20 Feb 2013 15:25 - 20 Feb 2013 15:26 #30350 by finemeca
Bonjour,
Ah super ça fonctionne :)
Il me reste à faire fonctionner mon radiobutton.
Dans custom-postgui j'ai fait :
loadrt mux4 count=1
addf mux4.0 servo-thread
setp mux4.0.in0 5
setp mux4.0.in1 1
setp mux4.0.in2 0.1
setp mux4.0.in3 0.01
net deplacement mux4.0.sel <= pyvcp.jog-speed.Rapide
Mais ça me retourne une erreur :
Print file information:
custom_postgui.hal:20: Pin 'mux4.0.sel' does not exist
Peux-tu m'aider svp à configurer mon radiobutton et hal ??
J'ai cherché dans la doc, mais il y a peu d'exemples.
Last edit: 20 Feb 2013 15:26 by finemeca.
20 Feb 2013 17:13 #30353 by ArcEye
Bonne Matin
Glad it worked for you.
The mux4 question is simple, there is no pin called mux4.<n>.sel, it is either sel0 or sel1 and the combination of the two gives you 4 possible input values to output.
sel1=FALSE, sel0=FALSE out follows in0
sel1=FALSE, sel0=TRUE out follows in1
sel1=TRUE, sel0=FALSE out follows in2
sel1=TRUE, sel0=TRUE out follows in3
I suggest you read these documents which give examples of using mux4 to control jog increments in different ways, and decide upon a method that suits your buttons etc
linuxcnc.org/docs/html/examples/mpg.html
wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding...imple_Remote_Pendant
22 Feb 2013 04:18 - 22 Feb 2013 04:27 #30425 by finemeca
Bonsoir,
Ok, je vais regarder du côté de glad. En attendant, avec pyvcp je vais utiliser des simples boutons :)
Merci pour ton aide.
Pierre
Last edit: 22 Feb 2013 04:27 by finemeca.
Moderators: darty367
Time to create page: 0.207 seconds
