Parametrage compact 5 PC
01 Dec 2014 06:45 #53552
by vb85
Parametrage compact 5 PC was created by vb85
Bonsoir,
J'ai un petit tour Emco compact 5 PC et j'ai des petits problèmes pour le paramétrage, il me faut un signal clock pour déverrouiller le latch.
Pour le choix de la carte, j'ai mis Autre, il y en a t'il une qui marche ?
Cordialement.
Cordialement.
01 Dec 2014 16:49 #53569
by ArcEye
Replied by ArcEye on topic Parametrage compact 5 PC
Hi
There are no card settings you can select for the Compact 5
See this link, skunkworks has converted several and describes his settings
bbs.homeshopmachinist.net/threads/59984-...o-interface-mods-%29
and also here
www.electronicsam.com/images/emco/linuxcnc_configs/Latest/
and also here
The following user(s) said Thank You: vb85
01 Dec 2014 22:57 - 01 Dec 2014 23:56 #53580
by vb85
Replied by vb85 on topic Parametrage compact 5 PC
Thank 's for the response,
But in the first part, SAMCO explain than he used the reset of printer for actived the latch of the 74.
I can't understand what he do ?
Sincerly
Sincerly
Last edit: 01 Dec 2014 23:56 by vb85.
02 Dec 2014 00:19 #53583
by ArcEye
Hi
I think you need to follow the links through to the configs, which end up at the same site as the second link
In his .hal file he sets
setp parport.0.reset-time 1000
setp parport.0.pin-01-out-invert 1
setp parport.0.pin-01-out-reset true
setp parport.0.pin-01-out true
I think this is what he is referring to.
Any detailed query you can't figure from the configs he supplies, really need to go to him
www.linuxcnc.org/index.php/english/my-pr...erprofile/skunkworks
So I hacked together a hal file that used the 'reset' function of the printer port driver to send a clock every base period to latch the 74ls374 chip
02 Dec 2014 15:45 #53594
by vb85
Thank's a lot ArcEye, I will try this week end, i will tell you last week if the result is good.
Bests regards.
Bests regards.
Moderators: darty367
