External E-Stop
17 Nov 2012 00:38 - 12 Nov 2013 20:35 #26684
by BigJohnT
External E-Stop was created by BigJohnT
This method uses the ESTOP_LATCH component to connect up an external physical E-Stop to LinuxCNC.
The typical estop loopback looks like this so either comment it out or remove it.John
# estop
loadrt estop_latch
addf estop-latch.0 servo-thread
net estop-loopout iocontrol.0.emc-enable-in <= estop-latch.0.ok-out
net estop-loopin iocontrol.0.user-enable-out => estop-latch.0.ok-in
net estop-reset iocontrol.0.user-request-enable => estop-latch.0.reset
net remote-estop estop-latch.0.fault-in <= parport.0.pin-in10-not
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
Last edit: 12 Nov 2013 20:35 by BigJohnT.
18 Nov 2012 12:21 #26739
by jmelson
code that I use with my hardware.
This links up a hardware Estop sense circuit and estop latch
with a software one in LinuxCNC. Anthing that breaks the
Estop sense loop in the hardware, or a software command
to go to E-stop will cause both hard and soft E-stop latches
to go to E-stop. Only when the hardware Estop chain is
closed and the software command is given to come out of E-stop
will it do so. The hardware also has a watchdog timer to cause
an E-stop if LinuxCNC stops controlling it.
The timing of these functions is critical, as handled
by the order of addf's in the ppmc_load.hal file.
addf and2.0 servo-thread
Since there is a delay of one servo cycle between sending a command to
the hardware and reading back the status, these operations have to be
done in the right order.
Jon
Replied by jmelson on topic External E-Stop
Well, if you are going to post hardware-specific code, I have to match that with theThis method uses the ESTOP_LATCH component to connect up an external physical E-Stop to LinuxCNC.
net remote-estop estop-latch.0.fault-in <= hm2_5i20.0.gpio.025.in_not
# connect e-stop write/sense to I/O controller
# and ppmc's fault with estop's output, so estop FF is reset, but
# prevent continued estop signal from ppmc from holding FF cleared
newsig ppmcEstop bit
linksp ppmcEstop ppmc.0.din.estop.in
linksp ppmcEstop and2.0.in0
newsig EstopOkIn bit
linksp EstopOkIn estop-latch.0.fault-in
linksp EstopOkIn and2.0.out
newsig EstopOkOut bit
#linksp EstopOkOut ppmc.0.dout.07.out
linksp EstopOkOut ppmc.0.dout.Estop.out
linksp EstopOkOut iocontrol.0.emc-enable-in
linksp EstopOkOut estop-latch.0.ok-out
linksp EstopOkOut and2.0.in1
newsig emc-estop-out bit
linksp emc-estop-out iocontrol.0.user-enable-out
linksp emc-estop-out estop-latch.0.ok-in
newsig emc-estop-reset bit
linksp emc-estop-reset iocontrol.0.user-request-enable
linksp emc-estop-reset estop-latch.0.reset
Jon
18 Nov 2012 22:02 #26751
by BigJohnT
That was not my intention I just quickly copied and pasted the example I had at hand.
Replied by BigJohnT on topic External E-Stop
19 Nov 2012 04:57 #26779
by jmelson
emoticons!
Jon
Just a little ribbing, I should have thrown in one of those
emoticons!
Jon
08 Aug 2016 16:04 #78495
by cparsons
Replied by cparsons on topic External E-Stop
I am trying to get my estop to work - and saw your example, I am going to do some experimenting but wondered if the line
should be
net remote-estop estop-latch.0.fault-in <= parport.0.pin-10-in-not
I also wondered what the line 'addf estop-latch.0 servo-thread' does - I don't have servos, I have stepper motors??
Regards
Chris
should be
Regards
Chris
- Thank you received: 5934
08 Aug 2016 17:06 #78496
Tom
Replied by tommylight on topic External E-Stop
Yes it should.I am trying to get my estop to work - and saw your example, I am going to do some experimenting but wondered if the line
should be
Regards
Chris
Tom
14 Aug 2016 21:49 #78775
by BigJohnT
If you don't have normally closed estop then yes you need to change the input.
The "servo-thread" is for some reason unknown to me means the slower thread with math and has nothing to do with the drives you may be using.
JT
should be
Regards
Chris
JT
14 Aug 2016 21:53 #78776
The first line has an error at "....in10-not....", should be ".....10-in-not".
regards,
Tom
regards,
Tom
30 Aug 2016 19:04 #79737
by OT-CNC
Replied by OT-CNC on topic External E-Stop
# estop
loadrt estop_latch
Thanks for posting this. My E-stop circuit is now improved.
I'd like to add my limits to the estop circuit through software if necessary. As physically wired, I can't run the limits in series with the estop. What is your opinion on this? This would protect the machine only from a drive failure. I'm using DMM servo drives in step mode and I don't know how they would react if an encoder wiring would fail down the road. Runaway? Or is it safe enough to rely on a drive enable signal to disable the drive? Linking the limit signal to disable the drives?
loadrt estop_latch
- LinfieldGarage
- Thank you received: 11
15 Jan 2019 19:01 - 15 Jan 2019 19:03 #124257
by LinfieldGarage
Replied by LinfieldGarage on topic External E-Stop
I know this is an old thread but it helped me get my estop working.
Here is a working config from my system running Master branch 2.8 and a Mesa 7i96 board. My estop button is N/C and is a 24 volt input to GPIO 010 on the Mesa board. Just change the last line for your particular board and GPIO pin.
# create a signal for the estop loopback
#config from BigJohn#
loadrt estop_latch
net remote-estop estop-latch.0.fault-in <= hm2_[HOSTMOT2](BOARD).0.gpio.010.in_not
loadrt estop_latch
Last edit: 15 Jan 2019 19:03 by LinfieldGarage.
Time to create page: 0.114 seconds
