Label
10 Jan 2012 07:02 #16509
by mhaberler
I updated the custom-label branch to retrieve the default background color, and set that if the pin value is zero.
git.mah.priv.at/gitweb/emc2-dev.git/shor...s/heads/custom-label
-m
-m
29 Jan 2012 15:11 - 29 Jan 2012 15:12 #17261
by BigJohnT
Michael,
I'm trying to add a second value dependent label and can't quite figure out what needs to be added. Starting with the simple example I've got this far... but I have a few questions.
#!/usr/bin/env python
import hal
import hal_glib
class HandlerClass:
def _on_value_change(self,hal_pin,data=None):
#print "_on_value_change() - HAL pin value: %s" % (hal_pin.get())
value = hal_pin.get()
if value < 0:
self.label.set_label("REVERSE")
elif value > 0:
self.label.set_label("FORWARD")
else:
self.label.set_label("OFF")
def _on_status_change(self,hal_pin,data=None):
if value < 0:
self.label.set_label("Drive OK")
elif value > 0:
self.label.set_label("Drive Broken")
else:
self.label.set_label("Drive Unknown")
def __init__(self, halcomp,builder,useropts):
self.halcomp = halcomp
self.builder = builder
# hal pins with change callback, unrelated to any HAL widget.
# When the pin's value changes the callback is executed.
self.inpin = hal_glib.GPin(halcomp.newpin('input-pin', hal.HAL_FLOAT, hal.HAL_IN))
self.inpin.connect('value-changed', self._on_value_change)
self.label = self.builder.get_object('label1')
# second pin
self.inpin = hal_glib.GPin(halcomp.newpin('status-pin', hal.HAL_FLOAT, hal.HAL_IN))
self.inpin.connect('value-changed', self._on_staus_change)
self.label = self.builder.get_object('label2')
# Does the line above need a unique name?
def get_handlers(halcomp,builder,useropts):
return [HandlerClass(halcomp,builder,useropts)]
Last edit: 29 Jan 2012 15:12 by BigJohnT.
29 Jan 2012 15:25 #17262
by mhaberler
ok, what happens is:
'label1' and 'label2' are the names given to the labels in glade
whereas self.label is a Python reference to an object (which is returned by builder.get_object(<name>)
just name the references identical like the string names - less confusing, like so:
self.label1 = self.builder.get_object('label1')
self.label2 = self.builder.get_object('label2')
you need to fix the references in the _on_... handlers, too
-m
# this makes self.label to refer to the 'label1' object
# the line below overwrites the above reference, so both
# _on_status_change and _on_value_change will
# change the label of the 'label2' object:
-m
01 Feb 2012 15:04 #17317
by BigJohnT
Ok, the label text changes as expected now as the drive status value changes YIPPIE!
However for some reason the background color changes for the drive status label and I can't spot my error...
import gtk
import hal
import hal_glib
class HandlerClass:
if value < 0:
self.label.set_label("REV")
self.eventbox.modify_bg(gtk.STATE_NORMAL, gtk.gdk.color_parse("red"))
elif value > 0:
self.label.set_label("FWD")
self.eventbox.modify_bg(gtk.STATE_NORMAL, gtk.gdk.color_parse("green"))
else:
self.eventbox.modify_bg(gtk.STATE_NORMAL, gtk.gdk.color_parse("#F5F5F5"))
def _on_status1_change(self,hal_pin,data=None):
print "_on_status1_change() - HAL pin value: %s" % (hal_pin.get())
if value == 0:
self.label2.set_label("Drive Status = No Faults")
elif value == 1:
self.label2.set_label("Drive Status = Over Current")
elif value == 2:
self.label2.set_label("Drive Status = Over Voltage")
elif value == 3:
<snip>
else:
self.label2.set_label("Drive Status = Unknown")
self.label = self.builder.get_object('spindle-direction')
self.eventbox = self.builder.get_object('eventbox1')
self.button = self.builder.get_object('hal_button1')
self.button.modify_bg(gtk.STATE_NORMAL, gtk.gdk.color_parse("yellow"))
self.button.modify_bg(gtk.STATE_PRELIGHT, gtk.gdk.color_parse("red"))
self.button.modify_bg(gtk.STATE_ACTIVE, gtk.gdk.color_parse("blue"))
# define gs2 status 1
self.inpin = hal_glib.GPin(halcomp.newpin('gs2-status1', hal.HAL_S32, hal.HAL_IN))
self.inpin.connect('value-changed', self._on_status1_change)
self.label2 = self.builder.get_object('gs2-status1')
self.eventbox = self.builder.get_object('eventbox2')
01 Feb 2012 15:20 #17318
by mhaberler
BigJohnT wrote:
I think it could have to do with this:
developer.gnome.org/gtk-faq/stable/x810.html
mail.gnome.org/archives/gtk-app-devel-li...anuary/msg00432.html
unit of coloring is an X window object and labels dont have their own for performance reasons methinks
Try putting the label inside a Event box which has an X window, and color this enclosing event box
can you post both glade and python files so I can try?
-Michael
-Michael
