How to integrate gladeVCP?
26 Jun 2012 08:00 #21335
by Revilo
How to integrate gladeVCP? was created by Revilo
Hey Hey,
it might be a stupid question for you but i am a bloody rookie in the whole story. never worked with linux, no experience in programming.
however my mill works....partially:)
my question now is: in the integrators manual they say:
Run the same panel as a tab inside Axis as follows:
$ cd configs/sim/gladevcp
$ linuxcnc gladevcp_tab.ini
where do i have to write these commands in?
i read something about git?what is it?
greetz
greetz
26 Jun 2012 10:58 #21351
by BigJohnT
Replied by BigJohnT on topic Re:How to integrate gladeVCP?
Usually when you see the dollar sign it means things you typed into the terminal window. And indeed those are terminal commands. For more info on that read
here
Unless you require a more complex Virtual Control Panel I would suggest starting with Python VCP it is a much simpler interface to add and use.
27 Jun 2012 15:48 #21392
Replied by andypugh on topic Re:How to integrate gladeVCP?
Revilo wrote:
In a terminal window. However I am not sure why the instructions say to do it that way, as it is equivalent to selecting LinuxCNC from the application menu, then selecting the sim/gladevcp configuration.
27 Jun 2012 20:11 #21414
by BigJohnT
andypugh wrote:
That is left over from when you could only get 2.5 as a git RIP.
Time to create page: 0.269 seconds
