how use the "EMC SourceView" of Glade
13 Sep 2012 22:56 #24250
by meduag
how use the "EMC SourceView" of Glade was created by meduag
Hi, I want know how use the EMC SourceView in gladevcp, and how I can import a text for display in the EMC SourceView
14 Sep 2012 00:06 #24255
by BigJohnT
Replied by BigJohnT on topic Re:how use the "EMC SourceView" of Glade
Well you just place it in a cell and it will display the currently loaded G code file. Have you seen my
GladeVCP tutorial
14 Sep 2012 04:38 #24261
Replied by cmorley on topic Re:how use the
you use 'emc action open' to load gcode into linuxcnc/sourceview
23 Sep 2012 18:47 #24566
by meduag
Replied by meduag on topic Re:how use the
you can give me an example using python and glade?
26 Sep 2012 11:48 #24641
by meduag
Hi everyone,
I try to use the EMC_SourceView, but after several attempts yet did not know how to use it.
I want to say best my idea to know if possible:
I have a format code "XXXX", I create a filter that passes for "XXXX" to code G / M, So far so good,
Then I want to put a window where you see the code "XXXX", after it is opened.
I made a glade with python program that opens the file, and I want to add it to the Axis GUI, but I need to run the archiyo. py of my program and do not know how?
annex a picture 1 to better understand
26 Sep 2012 11:49 #24642
by meduag
26 Sep 2012 13:17 - 26 Sep 2012 13:18 #24645
by BigJohnT
I "think" I know what you want to do. You want to pass your p21 file through your python filter then on to Axis.
Look at the Filter section of the INI chapter in the Integrators manual.
When you "open" your p21 file in Axis it will be run through your filter program which needs to output G code to standard out and that will be loaded into Axis.
Last edit: 26 Sep 2012 13:18 by BigJohnT.
26 Sep 2012 16:50 #24648
by meduag
26 Sep 2012 17:44 #24650
by BigJohnT
I don't know how to do that other than opening it up with your filter program perhaps in gedit.
27 Sep 2012 15:41 #24666
Replied by andypugh on topic Re:how use the
meduag wrote:
I know this isn't what you are asking for, but I guess that the filter programme could include the original code after a comment character, in the G-code programme.
Otherwise you need to edit the Axis GUI, and nobody understands that except the author.
I already did that , now I want to add a window to view the code P21 that was converted
Time to create page: 0.224 seconds
