Running a py file from a button
20 Sep 2012 12:48 #24454 by btvpimill
Not sure if this is the right forum, its a little about GladeVCP and a little advanced config. Move if needed PLEASE
I have written small py program that will change the HOME_OFFSET values for each axis in the INI file. My question is this:
I want to be able to press a button created with GladeVCP and have it run the code, but I also need it to pass the current joint positions to the code. I am not sure how to :
A) execute the code
and
B) pass the #xxxx values for current position. (I do know what each #xxxx is for each joint)
I am sure this is dead easy, but as yet I don't see it.
20 Sep 2012 15:22 #24462 by ArcEye
Hi
One way that springs to mind
net your button to halui.mdi-command.NN
Set that mdi command in your ini file to call a user M code file, M100 for example, passing the vars for the axes you want
For example 'M100 P#5221 Q#5222 will pass position of X and Y in G54 offset system
In your user M code file use the passed data to call your py program
for instance
#!/bin/bash
python mypyfile.py $1 $2
would pass the 2 arguments to M100 as arguments to your python file
20 Sep 2012 15:43 #24467 by andypugh
ArcEye wrote:
#!/bin/bash
I think that simply renaming the python file to M101 and having it start with #! bin/python ought to work.
It ought to be able to call the Python direct from Glade, though, without any need to mess about with pins in HAL:
www.linuxcnc.org/docs/html/gui/gladevcp....#_emc_action_widgets shows how to call an MDI command,
or look in section 8 for a neater way.
20 Sep 2012 15:59 #24471 by mhaberler
I recently found a clever Python module which makes it very easy to execute arbitrary shell commands:
amoffat.github.com/sh/index.html
- Michael
20 Sep 2012 16:06 #24473 by eszyman
We can load a handlers.py, per section 8, in fact, because I followed the tutorial, we already try to, although it does not exist yet! haha
20 Sep 2012 16:20 #24478 by btvpimill
Thanks Andy and Michael.
@Andy - is it true that with your method I can only pass P and Q? so only 2 arguments?
@Michael - that looks really intresting - and a bit over my head right now.
In any event, I would like to be able to pass all 9 joint locations, and best if they were G53 positions but I don't see that in the doc's for #parameters. I can live with position based on any Gxx enviroment as I can do the math backwards to get the true machine position, then pass the actual position to the script. OR just make sure there is no offsets loaded in the current Gxx offset system.
This may seem like a lot of work just to set the HOME_OFFSET values, but I am trying to make it more user friendly. (and keep users out of my configs where they will surely mess something up)
The end goal once this small step is achieved will be a config GUI much like stepconf, only able to deal with all 9 axis instead of 3, and allow you to edit existing configs without overwriting what has been done outside the scope of stepconf.
20 Sep 2012 16:22 #24479 by btvpimill
eszyman, does that mean we know how to pass all 9 joint positions also?
21 Sep 2012 08:33 #24501 by ArcEye
Yes, a limiting factor that if removed would open up a lot of possibilities.
... but I don't see that in the doc's for #parameters.
www.linuxcnc.org/docs/devel/html/gcode/o....html#sec:parameters
specifically
5420-5428 Current Position including all offsets and in the current program units for X, Y, Z, A, B, C, U, V & W. In absolute machine coordinates, volatile.
The easiest way at present to pass 9 co-ordinates would probably be to pass them in pairs to an intermediate script which writes to file, then your py program can open the file and read them.
21 Sep 2012 10:03 #24503 by btvpimill
Thanks ArcEye, looks like that intermediate step is how it will have to be done.
As for the parameters to be passed, My impression of the "current position set" (5420-5428) is it includes any active offsets. This is not a HUGE issue, but would be nice if there was a way to get the actual machine position, not the reported position after offsets.
21 Sep 2012 10:13 #24504 by mhaberler
the description
is a bit ambigouous - it IS in absolute machine coordinates, so the concept of offsets does not relate to these values.
- Michael
Moderators: mhaberlerHansU
