Return to manual mode after MDI command
19 Jan 2013 14:10 #28814
by Miselph
Return to manual mode after MDI command was created by Miselph
Hey Folks,
I have a glade panel which contains buttons which send MDI commands. The commands execute correctly but leave the machine in joint mode rather than telop mode. Is there a way of setting the mode back to telop after an mdi command has been run?
Thanks.
Thanks.
19 Jan 2013 14:25 #28815
by mhaberler
Replied by mhaberler on topic Return to manual mode after MDI command
are you using the Action widgets for MDI?
-m
-m
20 Jan 2013 11:57 #28852
by Miselph
Replied by Miselph on topic Return to manual mode after MDI command
Yes I am. I am using the toggle button linked to the MDI action toggle widget.
I am thinking that the solution may lie with a custom callback, but I am not sure where to start.
20 Jan 2013 15:00 #28857
by Miselph
So, I had a fiddle around. I couldn't figure out how to change a hal pin from gladevcp so I did it using a system call to halcmd
Here is my code, now tell me how wrong it is
I suspect that this is a non-optimal approach, but it does seem to work.
from subprocess import call
from time import sleep
class PanelHandlers:
def reset_manual_and_teleop(args1,args2):
call(["halcmd", "setp", "halui.mode.manual", "1"])
call(["halcmd", "setp", "halui.mode.teleop", "1"])
sleep(1)
call(["halcmd", "setp", "halui.mode.manual", "0"])
call(["halcmd", "setp", "halui.mode.teleop", "0"])
def get_handlers(halcomp,builder,useropts):
return [PanelHandlers()]
Time to create page: 0.071 seconds
