Gremlin preview plot for Touchy Gui
23 Jan 2013 14:26 #29005
by REEEN
Gremlin preview plot for Touchy Gui was created by REEEN
Good day everybody,
I`m trying to input a Gremlin preview plot into TOUCHY GUI by using a implemented Glade Window.
The problem is at the moment I can only input one Gremlin view into Touchy if I use more than one Gremlin view the Window won't show up.
I think it must be possible to insert more than one Gremlin preview into one Window because I have seen this:
psha.org.ru/tmp/touchy-gremlin.png
A Gremlin preview is a needed thing in a Gui, but only one view is not good enough.
Is there a possibility to make Buttons to select the different views and clean up the view as in axis?
Iam using Linuxcnc 2.6 with Touchy Gui.
Thanks for your help!
Sorry for my bad english I'm from Germany
Greets Rene
Greets Rene
23 Jan 2013 15:04 #29007
Replied by cmorley on topic Gremlin preview plot for Touchy Gui
I am not sure why multiple HAL_gremlins don't show.
You can create a window with buttons and HAL_gremlin.
Then using a gladevcp handler file connect them to call backs methods that change the view of the display.
So it's a bit of work if you don't know python programming.
It would be a good example for the manual....
Chris M
Chris M
The following user(s) said Thank You: REEEN
24 Jan 2013 03:31 #29040
by REEEN
Replied by REEEN on topic Gremlin preview plot for Touchy Gui
Sorry I don't know anything about python programming. ..
I think I have to live with one Gremlin...
Thank you!
Thank you!
- Kirk_Wallace
- Thank you received: 7
24 Jan 2013 10:24 #29057
by Kirk_Wallace
Replied by Kirk_Wallace on topic Gremlin preview plot for Touchy Gui
It looks like there is already a config with four gremlin views in Sample Files - gladevcp - touchy, which you can select from the configuration selector when LinuxCNC starts up.
Kirk Wallace
www.wallacecompany.com/machine_shop/
Kirk Wallace
Time to create page: 0.150 seconds
