GladeVCP and Keyboard.
- Connor9220
- Topic Author
04 Apr 2013 06:33 #32250
by Connor9220
GladeVCP and Keyboard. was created by Connor9220
How do you bind a key to a widget? I'm working with the hal_combobox. I want to be able to cycle through the options with one (or two if needed) keystorkes. Additionally, how do I tie the output value to a hal pin?
I'm using this to make a unit selector for the external jog wheel. I've got the XYZ buttons working now.. this the last thing I need.
Thanks, Connor
Thanks, Connor
04 Apr 2013 11:18 #32259
Replied by cmorley on topic GladeVCP and Keyboard.
Please explain how you want the key bindings to work.
Doesn't the up down keys work on it after selecting the combobox?
www.linuxcnc.org/docs/2.5/html/gui/glade...ladevcp:HAL_ComboBox
- Connor9220
- Topic Author
04 Apr 2013 12:01 #32261
by Connor9220
Replied by Connor9220 on topic GladeVCP and Keyboard.
Yes, Up/Down work if it's selected. I'm talking about quick key or hot key or whatever you want to call it. a key that I can use on the keyboard to operate the up/down without having to select the combo. Like the one in Axis. You can change the value by hitting the i key, or shift i to go back up.
04 Apr 2013 12:18 #32262
Ok GTK calls the widget accelerators.
I think his would require you to add python code to a gladeVCP handler file - gladeVCP knows nothing of accelerators.
www.pygtk.org/pygtk2tutorial/sec-WidgetAccelerators.html
The accelerator emits the signal that controls the widget
You have to attach an accelerator group to a top level window then attach an accelerator to a widget you want to control.
That may be a problem since when you embed gladeVCP into AXIS the toplevel widget is replaced and destroyed.
I don't know a lot more about this as I just read about them now and tried a button example example in Gscreen.
Hmm just looking in the GLADE editor of a combo box under common:
there is a entry for accelerator key selection - you could try that.
I don't have time to try it right now.
Chris M
Chris M
- Connor9220
- Topic Author
04 Apr 2013 23:26 #32278
by Connor9220
I've tried using the accelerator on the combo box under common already.. I think Axis is intercepting the key stroke request maybe? or like you said, not able to attach it to ta top level window since it' embedded with AXIS. Wonder if you could add some code to the .axisrc file and have it relay to the widget ?
Time to create page: 0.071 seconds
