tool edit gladevcp insert axis question
17 Apr 2013 12:43 #32823
Replied by cmorley on topic tool edit gladevcp insert axis question (resolved)
did you add an 'emc_stat" object?
then you add a hal_action
then a button then must select a related action for that button.
Chris M
Chris M
17 Apr 2013 19:49 - 18 Apr 2013 04:37 #32836
by jlviloria
Replied by jlviloria on topic tool edit gladevcp insert axis question (resolved)
Because in my gcode_view cursor does not appear if I have it enabled? please help.
How do I display the name of my program, instead of G code.
edit.py
import hal_glib
import gladevcp
import os
import sys
import pygtk
pygtk.require("2.0")
import gtk.gladevcp
import gtk
import gladevcp.makepins
from gladevcp.gladebuilder import GladeBuilder
import hal_widgets
import gobject
class HandlerClass:
def on_hal_status_file_loaded(self,widget,filename):
self.widgets.gcode_tab.set_text(name)
self.builder.get.object('gcode_tab').set_tex(_("Program loaded: %s"%filename))
def __init__(self, halcomp,builder,useropts):
self.halcomp = halcomp
self.builder = builder
self.nhits = 0
def get_handlers(halcomp,builder,useropts):
return [HandlerClass(halcomp,builder,useropts)]
thanks
jorge Viloria
edit.py
import hal_glib
import gladevcp
import os
import sys
import pygtk
import gtk.gladevcp
import gtk
import hal_widgets
import gobject
class HandlerClass:
self.nhits = 0
thanks
jorge Viloria
Last edit: 18 Apr 2013 04:37 by jlviloria.
Time to create page: 0.062 seconds
