help with some problems on Tutorial 1 for GladeVcp
18 Dec 2013 07:56 - 18 Dec 2013 07:57 #41725
by gww250
help with some problems on Tutorial 1 for GladeVcp was created by gww250
I finally got glade installed properly and started following the tutorial at this location:
. The URL is gnipsel.com/linuxcnc/gui/gui01b.html
I did a copy and paste of the code but built the glade file from scratch. When I follow the instructions I get the following error messages in the terminal:
user@dell-d610:~$ #!/usr/bin/env python
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$ import pygtk
user@dell-d610:~$
user@dell-d610:~$ pygtk.require("2.16")
bash: syntax error near unexpected token `"2.16"'
user@dell-d610:~$
user@dell-d610:~$ import gtk
user@dell-d610:~$
user@dell-d610:~$ import gladevcp.makepins
user@dell-d610:~$
user@dell-d610:~$ from gladevcp.gladebuilder import GladeBuilder
user@dell-d610:~$
user@dell-d610:~$ import hal
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$ class gui_one(object):
bash: syntax error near unexpected token `('
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$ def on_MainWindow_destroy(self, widget, data=None):
user@dell-d610:~$
user@dell-d610:~$ print "quit with cancel"
Warning: unknown mime-type for "quit with cancel" -- using "application/octet-stream"
Error: no such file "quit with cancel"
user@dell-d610:~$
user@dell-d610:~$ gtk.main_quit()
> def on_gtk_quit_activate(self, menuitem, data=None):
bash: syntax error near unexpected token `def'
user@dell-d610:~$
user@dell-d610:~$ print "quit from menu"
Warning: unknown mime-type for "quit from menu" -- using "application/octet-stream"
Error: no such file "quit from menu"
user@dell-d610:~$
> def __init__(self):
user@dell-d610:~$
user@dell-d610:~$ self.builder = gtk.Builder()
user@dell-d610:~$
user@dell-d610:~$ self.builder.add_from_file("gui1.glade")
bash: syntax error near unexpected token `"gui1.glade"'
user@dell-d610:~$
user@dell-d610:~$ halcomp = hal.component("gui01")
user@dell-d610:~$
user@dell-d610:~$ self.builder.connect_signals(self)
bash: syntax error near unexpected token `self'
user@dell-d610:~$
user@dell-d610:~$ self.window = self.builder.get_object("MainWindow")
user@dell-d610:~$
user@dell-d610:~$ self.window.show()
> panel = gladevcp.makepins.GladePanel( halcomp, "gui1.glade", self.builder, None)
bash: syntax error near unexpected token `panel'
user@dell-d610:~$
user@dell-d610:~$ halcomp.ready()
> if __name__ == "__main__":
> app = gui_one()
user@dell-d610:~$
user@dell-d610:~$ gtk.main()
What am I doing wrong?
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
> def __init__(self):
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
user@dell-d610:~$
> app = gui_one()
user@dell-d610:~$
Last edit: 18 Dec 2013 07:57 by gww250. Reason: url not showing up
18 Dec 2013 08:58 #41731
by mhaberler
Replied by mhaberler on topic help with some problems on Tutorial 1 for GladeVcp
you obviously pasted python code into a shell window
save the code in a file, say example.py
then run it with
$ python example.py
then run it with
$ python example.py
18 Dec 2013 09:14 #41732
by gww250
Replied by gww250 on topic help with some problems on Tutorial 1 for GladeVcp
I tried that first and the terminal screen just flashed and disappeared. The gui didn't show up.
18 Dec 2013 09:27 #41733
by gww250
I removed the pygtk require ("2.6") line and it finally ran, sort of. Here is the ouput result:
gui1.py:23: RuntimeWarning: missing handler 'on_window1_destroy'
gui1.py:23: RuntimeWarning: missing handler 'on_quit_activate'
File "gui1.py", line 30, in <module>
app = gui_one()
File "gui1.py", line 25, in __init__
self.window.show()
AttributeError: 'NoneType' object has no attribute 'show'
user@dell-d610:~/linuxcnc/configs/laser2gui$
app = gui_one()
self.window.show()
18 Dec 2013 15:39 #41743
Replied by cmorley on topic help with some problems on Tutorial 1 for GladeVcp
John's turtorial has:
pygtk.require("2.0") which is not the same as 2.16 or 2.6
The last problem you have is most likely that the window in the glade file is not named right.
Default name in GLADE is window1, John's python program expects it to be MainWindow
change one of them.
John you shouldn't be so tricky to newbies
Chris M
change one of them.
Chris M
18 Dec 2013 20:54 - 18 Dec 2013 20:58 #41756
by BigJohnT
Didn't mean to be but if he skipped tutorial 1 then that could lead to some confusion... do I even need the pygtk.require?
Well it looks like I changed back to window1 in almost all places... fixing that now.
JT
Replied by BigJohnT on topic help with some problems on Tutorial 1 for GladeVcp
change one of them.
Chris M
JT
Last edit: 18 Dec 2013 20:58 by BigJohnT.
18 Dec 2013 21:14 #41758
by BigJohnT
gww250 please refresh any pages from 1-5 where I had the confusion about the MainWindow vs window1. Seems I reverted back calling the main window MainWindow in most places but forgot to change it in some places. Also if you have downloaded any files from 1-5 download the corrected ones.
JT
JT
19 Dec 2013 00:16 #41774
by gww250
You're right about window1 and MainWindow. I printed out all of the tutorial pages and didn't notice the change so i was using window1 while the code I pasted called for MainWindow. Runs fine now except for the quit button in the menu but I can fix that.
I really appreciate the help. I've been using Linuxcnc for about two years but this is the first I've ever tried to customize a control panel.
20 Dec 2013 10:42 #41856
by gww250
Things are moving along nicely. These are great tutorials but I've run into a snag with the python file from part 3b where we create a standalone sim gui. The error occurs at this line:
libdir = os.path.join(BASE, "lib", "python")
And the message simply states : syntax error: invalid syntax
Any ideas?
Any ideas?
20 Dec 2013 17:13 #41864
It tried the code on Johns page and found no syntax errors.
I didn't have the glade file so can't say if it actually works ..
make sure you typed it right.
Chris M
Chris M
