help with some problems on Tutorial 1 for GladeVcp
20 Dec 2013 20:25 - 20 Dec 2013 20:41 #41871
by BigJohnT
Replied by BigJohnT on topic help with some problems on Tutorial 1 for GladeVcp
I also ran the first part of the file in a python terminal with no errors. I suspect a typo.
I also just ran the example from a RIP with no errors.
JT
#!/usr/bin/env python
import gtk
import gobject
import gladevcp.makepins
from gladevcp.gladebuilder import GladeBuilder
import hal
import sys,os
# set up paths to files
BASE = os.path.abspath(os.path.join(os.path.dirname(sys.argv[0]), ".."))
libdir = os.path.join(BASE, "lib", "python")
sys.path.insert(0, libdir)
datadir = os.path.join(BASE, "share", "linuxcnc")
xmlname = os.path.join(datadir,"gui3.glade")
JT
Last edit: 20 Dec 2013 20:41 by BigJohnT.
21 Dec 2013 08:30 #41894
by gww250
Replied by gww250 on topic help with some problems on Tutorial 1 for GladeVcp
I never did find a problem in that code but after switching over to my other computer it runs with only a minor error which is as follows:
File "laser5-alone.py", line 19, in <module>
class laser5(object):
File "laser5-alone.py", line 79, in laser5
app = laser5()
NameError: name 'laser5' is not defined
Do I need to change the name of the python program to match the name of the Glade file? I.E. use laser5.py and laser5.glade.
app = laser5()
Time to create page: 0.106 seconds
