PyNgcGui Build Fault
17 Feb 2014 23:52 #43919
by LAIR82
PyNgcGui Build Fault was created by LAIR82
Hello Guys,
I am freshening up one of my turning centers that is running Gscreen, it was about 8 months behind on being current with all of the updates that have been made to it. Last week I did the same exact routine on another turning center, getting it current, and had no issues, today is a different story,
I am getting the following when trying to start linux now, I went back and re-compiled to see if maybe there might have been an issue, but came up with the same result.
Here is the fault,
cinci15cc@cinci15cc:~/linuxcnc-dev$ linuxcnc
LINUXCNC - 2.6.0~pre
Machine configuration directory is '/home/cinci15cc/linuxcnc/configs/15cc'
Machine configuration file is 'mygscreen.ini'
Starting LinuxCNC...
io started
halcmd loadusr io started
INFO CLASSICLADDER- No ladder GUI requested-Realtime runs till HAL closes.
task pid=5364
emcTaskInit: using builtin interpreter
/usr/lib/pymodules/python2.6/gtk-2.0/gobject/__init__.py:114: Warning: cannot register existing type `PyNgcGui'
type_register(cls, namespace.get('__gtype_name__'))
File "/home/cinci15cc/linuxcnc-dev/bin/gscreen", line 37, in <module>
import gladevcp.makepins
File "/home/cinci15cc/linuxcnc-dev/lib/python/gladevcp/__init__.py", line 1, in <module>
from hal_pythonplugin import *
File "/home/cinci15cc/linuxcnc-dev/lib/python/gladevcp/hal_pythonplugin.py", line 35, in <module>
from hal_pyngcgui import PyNgcGui
File "/home/cinci15cc/linuxcnc-dev/lib/python/gladevcp/hal_pyngcgui.py", line 31, in <module>
class PyNgcGui(gtk.Frame,hal_actions._EMC_ActionBase):
File "/usr/lib/pymodules/python2.6/gtk-2.0/gobject/__init__.py", line 60, in __init__
cls._type_register(cls.__dict__)
File "/usr/lib/pymodules/python2.6/gtk-2.0/gobject/__init__.py", line 114, in _type_register
RuntimeError: could not create new GType: PyNgcGui (subclass of GtkFrame)
Running HAL shutdown script
Cleanup done
LinuxCNC terminated with an error. You can find more information in the log:
/home/cinci15cc/linuxcnc_debug.txt
and
/home/cinci15cc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Any thoughts?
Rick
Here is the fault,
io started
task pid=5364
Cleanup done
and
Any thoughts?
Rick
18 Feb 2014 00:15 #43920
by dgarrett
Replied by dgarrett on topic PyNgcGui Build Fault
see
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...e20728207bb940f8a86c
you can remove the files manually, or safer:
cd your_linuxcnc_root
git clean -nfd # to see what would be removed
git clean -xfd # to remove them
you can also cd to a lower directory in the tree to use git clean
18 Feb 2014 00:37 #43921
by LAIR82
Replied by LAIR82 on topic PyNgcGui Build Fault
Does this look right/ok?
cinci15cc@cinci15cc:~/linuxcnc-dev$ git clean -nfd
Would remove configs/Sherline3Axis/
Would remove configs/SherlineLathe/
Would remove configs/cooltool/
Would remove configs/demo_sim_cl/
Would remove configs/demo_step_cl/
Would remove configs/halui_pyvcp/
Would remove configs/lathe-pluto/
Would remove configs/motenc/
Would remove configs/stepper/
Would remove configs/stg/
Would remove configs/vti/
Would remove lathe_style_tool_change2.patch
Would remove lathe_style_toolchange_G10_fix.patch
Would remove lib/python/gladevcp/pyngcgui.py
Would remove lib/python/stepconf/
Would remove python/
Would remove share/emc/
Would remove share/linuxcnc/stepconf/
Would remove src/config.h.in~
Rick
Rick
18 Feb 2014 01:02 #43923
by dgarrett
git clean will remove items that _you_ have added to the tree and leftovers from structural changes to the tree (like Would remove lib/python/gladevcp/pyngcgui.py)
It is generally safe to use unless one of the files identified for removal is one you have added.
18 Feb 2014 02:46 #43925
by LAIR82
That did the trick, it started up just fine now.
Rick
Rick
Time to create page: 0.127 seconds
