myAXIS.glade + .py work only in stand alone window
- gfxx
- Topic Author
- Visitor
05 Jun 2014 04:44 - 05 Jun 2014 16:58 #47689
by gfxx
myAXIS.glade + .py work only in stand alone window was created by gfxx
I'm able to work fine myaxis.glade file, myaxis.py and myaxis.hal file in AXIS if put my panel in EMBD_TAB section in .ini file ..... but if put it in GLADEVCP section the panel work only in for myaxis.hal_xxxx pin........ other user button, label and entry not work as expect...... I belive myaxis.py not work.
Where I find specific doc for integrating custom gladevcp panel with .py file?
Tank for any suggestion ..... I read JonT Gladevcp tutorial but I not find this particular explanation.
Last edit: 05 Jun 2014 16:58 by gfxx.
- gfxx
- Topic Author
- Visitor
05 Jun 2014 15:40 - 05 Jun 2014 17:02 #47709
by gfxx
Replied by gfxx on topic myAXIS.glade + .py work only in stand alone window
My mistake ..... the program run only in separate window mode ...... I don't now why yesterday night I see these wrong situation ..... Now in TAB mode or in PANEL mode with axis my program not run. Only Hal_pin take effect .... but myaxis.py not run. In separate window mode it is all ok...
file.ini
file.mod.hal
file modifica10.py
file POSIZIONI.glade
see file ....
Where is my error??
file.ini
[EMC]
MACHINE = KBV_K2
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 5
PROGRAM_PREFIX = /home/k1/linuxcnc/PROVA1
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
GLADEVCP = -u modifica10.py -H mod.hal -d /home/k1/Scrivania/LAVORO/KBV_K2/POSIZIONI.glade
#GLADEVCP = -H com.hal /home/k1/Scrivania/LAVORO/KBV_K2/comandi.glade
#EMBED_TAB_NAME = GESTIONE
#EMBED_TAB_COMMAND = gladevcp -u modifica10.py -H mod.hal -x {XID} /home/k1/Scrivania/LAVORO/KBV_K2/POSIZIONI.glade
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 50000
SERVO_PERIOD = 1000000
[HAL]
HALUI = halui
HALFILE = KBV_K2.hal
HALFILE = custom.hal
POSTGUI_HALFILE = mod.hal
#POSTGUI_HALFILE = com.hal
file.mod.hal
#loadusr -n gladevcp gladevcp -c gladevcp -u modifica10.py POSIZIONI.glade
#loadusr -Wn modifica10 python modifica10.py
net xpos-fb stepgen.0.position-fb => gladevcp.hal_label1
net ypos-fb stepgen.1.position-fb => gladevcp.hal_label2
net zpos-fb stepgen.2.position-fb => gladevcp.hal_label3
net dout-01 => gladevcp.hal_led1
net dout-02 => gladevcp.hal_led2
net estop-out => gladevcp.hal_led5
file modifica10.py
#!/usr/bin/env python3
#from Tkinter import *
import sqlite3
from time import sleep
from random import randint
import sys
import linuxcnc
import gtk
import hal_glib
import hal
import os
import time
import glib
import gobject
import gladevcp.makepins
from gladevcp.gladebuilder import GladeBuilder
try:
import pygtk
pygtk.require("2.0")
except:
pass
try:
import gtk
import gtk.glade
except:
sys.exit(1)
comune = 0
#xmlname = "/home/k1/linuxcnc/PROVA1/POSIZIONI.glade"
xmlname = "/home/k1/Scrivania/LAVORO/KBV_K2/POSIZIONI.glade"
class N:
x0 = str
y0 = str
x1 = str
y1 = str
x2 = str
y2 = str
x3 = str
y3 = str
caso = 0
class HandlerClass:
def __init__(self, halcomp, builder, useropts):
self.halcomp = halcomp
self.builder = builder
self.nhits = 0
def get_handlers(halcomp, builder, useropts):
return [HandlerClass(halcomp, builder, useropts)]
class AppGlade(object):
def __init__(self):
self.emc = linuxcnc
self.error_channel = self.emc.error_channel()
self.s = self.emc.stat()
self.c = self.emc.command()
self.builder = gtk.Builder()
self.builder.add_from_file(xmlname)
self.halcomp = hal.component("modifica10")
dic={
#"on_leggi_clicked" :self.cicla,
#"on_ok_clicked" :self.xx0,
"on_button1_clicked" :self.quit,
self.builder.connect_signals( dic )
self.builder.connect_signals(self)
self.window = self.builder.get_object("window1")
self.window.set_default_size(300, 500)
self.window.show()
self.panel = gladevcp.makepins.GladePanel(self.halcomp, xmlname, self.builder, None)
self.halcomp.ready()
gobject.timeout_add(500, self.periodic)
self.machine_status = 0
def periodic(self):
lettura()
self.error_status = self.error_channel.poll()
if self.error_status:
self.error_kind, self.error_text = self.error_status
if self.error_kind in (linuxcnc.NML_ERROR, linuxcnc.OPERATOR_ERROR):
self.error_type = "Error "
else:
self.error_type = "Info "
#self.message_id = self.statusbar.push(0, self.error_type + self.error_text)
self.s.poll()
data0 = self.s.actual_position[0]
data1 = self.s.actual_position[1]
data2 = self.s.actual_position[2]
#text = "% 9.4f"% (data)
self.halcomp.hal_label1 = round(data0,4)
self.halcomp.hal_label2 = round(data1,4)
self.halcomp.hal_label3 = round(data2,4)
self.builder.get_object("ex0").set_text(str(N.x0))
self.builder.get_object("ey0").set_text(str(N.y0))
self.builder.get_object("ex1").set_text(str(N.x1))
self.builder.get_object("ey1").set_text(str(N.y1))
self.builder.get_object("ex2").set_text(str(N.x2))
self.builder.get_object("ey2").set_text(str(N.y2))
self.builder.get_object("ex3").set_text(str(N.x3))
self.builder.get_object("ey3").set_text(str(N.y3))
return True
# def postgui(self)
# inifile = linucnc.ini(self.ini_file)
# postgui_halfile = inifile.find("HAL", "POSTGUI_HALFILE")
# return postgui_halfile,sys.argv[2]
def quit(self, object):
sys.exit(0)
#self.window.hide()
def cicla(self, object):
lettura()
def lettura():
conn = sqlite3.connect('/home/k1/linuxcnc/PROVA1/interfaccia_posizioni')
conn.row_factory = sqlite3.Row
c = conn.cursor()
c.execute("SELECT x, y FROM posizioni WHERE ROWID = (SELECT MIN(ROWID) FROM posizioni)")
rows = c.fetchall()
if len(rows) != 0:
for row in rows:
N.x0 = row[0]
N.y0 = row[1]
else:
N.x0 = "2"
N.y0 = "2"
c.execute("SELECT x, y FROM posizioni WHERE ROWID = (SELECT MIN(ROWID) FROM posizioni) + 1")
rows = c.fetchall()
if len(rows) != 0:
for row in rows:
N.x1 = row[0]
N.y1 = row[1]
else:
N.x1 = "2"
N.y1 = "2"
c.execute("SELECT x, y FROM posizioni WHERE ROWID = (SELECT MIN(ROWID) FROM posizioni) + 2")
rows = c.fetchall()
if len(rows) != 0:
for row in rows:
N.x2 = row[0]
N.y2 = row[1]
else:
N.x2 = "2"
N.y2 = "2"
c.execute("SELECT x, y FROM posizioni WHERE ROWID = (SELECT MIN(ROWID) FROM posizioni) + 3")
rows = c.fetchall()
if len(rows) != 0:
for row in rows:
N.x3 = row[0]
N.y3 = row[1]
else:
N.x3 = "2"
N.y3 = "2"
conn.close()
if __name__ == "__main__":
cal = AppGlade()
gtk.main()
see file ....
Where is my error??
Last edit: 05 Jun 2014 17:02 by gfxx.
- gfxx
- Topic Author
- Visitor
05 Jun 2014 17:01 #47711
by gfxx
I change the title of post ..... because I see this is the real problem: my.glade and my.py work perfect with axis only in separate window ..... if try to insert them in axis in panel or tab mode the my.py program not start
Time to create page: 0.096 seconds
