glade-gtk2 crash when adding MDI Action
07 Apr 2015 15:58 #57601
by DaBit
glade-gtk2 crash when adding MDI Action was created by DaBit
I am trying to create a simple GladeVCP panel with buttons that should trigger O-word subroutines. I did that before on my previous machine which used Ubuntu 10.04/LinuxCNC 2.5 and that was a smooth experience.
Not this time on Wheezy / LinuxCNC master as RIP. When trying to add a 'MDI Action' glade-gtk2 crashes:
There really isn't much in the panel yet:
I am running glade-gtk2 from a terminal window where I sourced the rip-environment script and gtk2-engines/gtk2-engines-xfce is installed.
Also, I seem to be unable to set the status of a checkbox to 'checked' by default. I can set the 'Active' property to 'yes', but that is ignored.
(glade-3:16217): GLib-GObject-WARNING **: /build/buildd-glib2.0_2.33.12+really2.32.4-5-i386-eISom6/glib2.0-2.33.12+really2.32.4/./gobject/gtype.c:4206: type id `0' is invalid
(glade-3:16217): GLib-GObject-WARNING **: can't peek value table for type `<invalid>' which is not currently referenced
Segmentation fault
dabit@snsmill:~/linuxcnc/configs/sim.axis$
21 Nov 2017 18:26 #102150
by jpa
Replied by jpa on topic glade-gtk2 crash when adding MDI Action
I found a workaround that seems to avoid the crash:
1. Select "VCP Action MDI" from left panel
2. Right click widget list in top right and select "Add widget as top level".
22 Nov 2017 08:24 #102176
by DaBit
Replied by DaBit on topic glade-gtk2 crash when adding MDI Action
Indeed, al those Actions should be at the top level to prevent this.
28 Nov 2017 15:47 #102438
by Mech john
Replied by Mech john on topic glade-gtk2 crash when adding MDI Action
Is this problem also effecting the probe_screen panel from the russian guy 'verser' it worked great but I upgraded to latest linuxcnc version and now I get strange 'have to be in mdi mode...' error messages when I try to use it. Seems to me it is a glade problem but I have no real experience with this...
cheers, John
cheers, John
07 Dec 2017 16:48 #102748
by newbynobi
Replied by newbynobi on topic glade-gtk2 crash when adding MDI Action
It is an axis problem!
It is known and will probably be solved soon.
It does work with master and gmoccapy.
Norbert
Norbert
Time to create page: 0.076 seconds
