Adding new function to python interface
11 May 2015 07:37 #58551
by sdfzz
Adding new function to python interface was created by sdfzz
Hi all,
I am trying to create a new GUI using GladeVCP. I found that I need a python file for NML interface. The list of available functions for python interface is provided in:
linuxcnc.org/docs/html/common/python-interface.html
However, what if I want to add a new function? For example, what if I want to create a new button on my GUI, and link my custom function to it? What is the source file for python interface functions?
Any help would be greatly appreciated
Regards,
Steve
Regards,
Steve
11 May 2015 08:21 #58552
by sdfzz
Replied by sdfzz on topic Adding new function to python interface
well... I found from google that the source file is:
github.com/jepler/linuxcnc-mirror/blob/m...ensions/emcmodule.cc
11 May 2015 13:17 #58556
by ArcEye
Replied by ArcEye on topic Adding new function to python interface
That file is the one which provides python methods from C
Have you read JTs tutorial on GUI writing?
gnipsel.com/linuxcnc/gui/index.html
Also study the code in Axis, touchy, gmoccapy.
All the methods you need should already be available, primarily from importing 'linuxcnc'
11 May 2015 13:21 #58557
by sdfzz
ArcEye, thank you for your reply
I will check out JTs tutorial on GUI
11 May 2015 23:07 #58565
I think that it is possible that you are misunderstanding the Python interface. I don't know if there is anything that could be there that isn't. (You can't just add extra members to the command or status structures if the est of linuxCNC doesn't know what to do with them.
Rather than jump straight to your solution, why not tell us your problem so we can suggest our solutions?
Replied by andypugh on topic Adding new function to python interface
12 May 2015 04:12 #58575
by newbynobi
Replied by newbynobi on topic Adding new function to python interface
I miss the remap level, homing status is wrong IMHO, etc,
Norbert
Norbert
12 May 2015 05:58 #58579
by sdfzz
Hi andypugh,
Actually, I am working on a project to create a LinuxCNC GUI which allows the users to display/adjust servo drive settings (such as filter cut-off frequencies or gains) and perform auto-tuning.
As far as I know, these features are not provided in LinuxCNC GUIs, and I understand that I may have to add a bunch of functions to LinuxCNC itself, as well as the GUI python script, to perform these tasks.
But, at this point, I'm not sure how the nml messages are handled in LinuxCNC, and which are the files that I need to modify.
I guess it is not an easy task...
Any suggestions?
regards,
Steve
Any suggestions?
regards,
Steve
12 May 2015 06:36 #58581
There is an auto-tuning pid HAL component:
manpage: www.linuxcnc.org/docs/html/man/man9/at_pid.9.html
Source and comments: git.linuxcnc.org/gitweb?p=linuxcnc.git;a...2ba48366a16c5e0ca67b
In principle all that needs is a few buttons to twiddle the HAL pins.
One caveat: I don't know if it actually works, it has the feel of a university project which got marked and was then forgotten.
