Can glade switch Axis between manual and mdi mode
19 Jun 2015 23:09 #59994
by tome
Can glade switch Axis between manual and mdi mode was created by tome
I have a set of buttons that in a Glade panel that lets the user select a tool from the tool changer. The Glade button simply runs an EMC_Action_MDI to do "M6 Tx" (where x is the tool number). When the user clicks one of these buttons Axis switches to the MDI mode tab. Is there any simple way (in Glade) to have it switch back to manual mode (if it was in manual mode when the user pressed the button)?
-Tom
-Tom
19 Jun 2015 23:56 #59995
by ArcEye
Replied by ArcEye on topic Can glade switch Axis between manual and mdi mode
One way is look at halui.mode
www.linuxcnc.org/docs/devel/html/gui/halui.html
Need to see if Axis updates itself though.
There is an issue with Axis that some things are in internal state and others are fetched from the underlying system,
can't remember if this affects mode or not.
It is quite possible to get out of synch with it.
Otherwise see .....src/emc/usr_intf/axis/extensions/emcmodule.cc for how Axis does it
20 Jun 2015 10:02 #60010
Replied by cmorley on topic Can glade switch Axis between manual and mdi mode
You would have to add a handler file and some python code to the GLADE panel.
www.linuxcnc.org/docs/2.6/html/gui/glade...eaning_up_afterwards
Chris M
Chris M
