gladevcp don't run
05 Jul 2015 01:02 #60411
by jtc
gladevcp don't run was created by jtc
Hi.
I'm trying to open a file with gladevcp, but I get this error:
I's using a virtual machine with ubuntu 12.04 and a run in place installation.
If I run glade, I can't have access to LinuxCNC-specific widgets, but I can run a sample configuration...
João
RTAPI: ERROR: could not open shared memory (errno=2)
Segmentation fault (core dumped)
jtc@ubuntu:~$ . /home/jtc/linuxcnc-dev/scripts/rip-environment
jtc@ubuntu:~$ cd linuxcnc-dev/configs/sim/axis/gladevcp/
jtc@ubuntu:~/linuxcnc-dev/configs/sim/axis/gladevcp$ gladevcp manual-example.ui
jtc@ubuntu:~/linuxcnc-dev/configs/sim/axis/gladevcp$ linuxcnc
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/jtc/linuxcnc-dev/configs/sim/axis/gladevcp'
Machine configuration file is 'gladevcp_tab.ini'
Starting LinuxCNC...
João
05 Jul 2015 03:46 #60420
Replied by cmorley on topic gladevcp don't run
I'm not sure about the seg faultbut you must use glade-gtk2 for gadevcp.
I believe Ubuntu 12.04 usually has glade gtk3 stock. You can probably download the right one through official Ubuntu repositories.
The samples work because they were built with the proper grade editor.
Chris M
Chris M
The following user(s) said Thank You: jtc
05 Jul 2015 04:23 - 05 Jul 2015 04:27 #60422
by jtc
Replied by jtc on topic gladevcp don't run
ok, its no running with hal/python and VCP actions showed on glade.
to be able to run it, I use this command:
in the tutorials its used "gladevcp myui.ui" (www.linuxcnc.org/docs/html/gui/gladevcp....adevcp:Prerequisites)
edit:
I tested on debian, and using "glade-gtk2" instead of "gladevcp" works fine, so the documentation looks like to be outdated.
jtc@ubuntu:~/linuxcnc-dev/configs/sim/axis/gladevcp$ glade-gtk2 manual-example.ui
edit:
Last edit: 05 Jul 2015 04:27 by jtc.
06 Jul 2015 03:51 #60445
where in manual please?
Those are two different commands.
one is to open the GLADE editor preloaded with a panel
the other is to display the panel within HAL environment.
Chris M
Chris M
06 Jul 2015 04:00 #60446
by jtc
not in manual, its in the last link.
I was referring to open the glade editor with linuxcnc modules.
06 Jul 2015 04:16 #60448
ok I looked at link..seems it's right...it was referring to _running_ the panel...you say you want to _edit_ the panel.
Glad you got it figured out
Chris M
Chris M
Time to create page: 0.157 seconds
