GladeVCP in LinuxMint
29 Nov 2015 12:11 - 29 Nov 2015 12:26 #65998
by BigJohnT
GladeVCP in LinuxMint was created by BigJohnT
I've got LinuxMint with the Mate desktop up and going with the RTAI kernel and LinuxCNC 2.7 installed. I installed Glade and the version is 3.16.1. There are no LinuxCNC widgets, how do I add them?
Edit: a bit of searching and I found these
forum.linuxcnc.org/forum/48-gladevcp/281...heezy-iso-2-6-0-pre5
sourceforge.net/p/emc/bugs/352/
which seem to indicate that gladevcp is going away because of some issue with newer versions of Glade.
JT
JT
Last edit: 29 Nov 2015 12:26 by BigJohnT.
29 Nov 2015 13:04 #65999
by cncbasher
Replied by cncbasher on topic GladeVCP in LinuxMint
make sure you install glade2
29 Nov 2015 13:31 #66001
by BigJohnT
Replied by BigJohnT on topic GladeVCP in LinuxMint
Ok, I found out how to install Glade 3.8 which is the last version to support GTK2.
I wonder what the future is for stuff like this?
JT
sudo apt-get install glade-gtk2
JT
29 Nov 2015 19:48 - 29 Nov 2015 19:49 #66032
Replied by cmorley on topic GladeVCP in LinuxMint
your glade panels will continue to work well into the future.
The ability to edit them in a current distribution is close extinction.
So the two choices is forward port glade-gtk2 (which Ubuntu has done yaay)
or convert gladevcp to use GTK3 and the newer GLADE editor.
I have done work on gladeVCP for gtk3 but am stumbling on a gremlin replacement.
Anyone who is a opengl kinda guy would be very helpful.
There is a branch with most of my work on our repo.
Chris M
Chris M
Last edit: 29 Nov 2015 19:49 by cmorley.
29 Nov 2015 21:07 #66054
by BigJohnT
Have you found GTK3 to be stable? When I tried it was kinda buggy. I'll look for your branch in the morning.
JT
JT
30 Nov 2015 05:18 #66088
my branch is now very behind and incomplete. I don't think I pushed my latest work and it's all for not without a graphics plotter.
The coolest part is I could actually make it so it would use gtk2 or gtk3 depending what was required.
Yes GTK3 with python is difficult to find examples and some libraries have not been converted.
Chris M
Chris M
Time to create page: 0.177 seconds
