Lable Change by HAL Radio Button?
- Topic Author
- Thank you received: 1369
05 Feb 2016 14:06 #69651
That is right, It is just a easy (for the operator not for me) way for the operator to make simple incremental adjustments to the G54 machine coordinate system, rather than use the "touchoff system" This is much simpler for the way we use this machine. (It is for a gang router that is used for engraving multiple items.)
I've already made a similar pyvcp panel (and a huge pile of halui commands and subroutines) for another of our carving machines. This time I wanted to try glade which removed the need for halui and most of the subs, but the python part is kicking my butt.
Replied by Todd Zuercher on topic Lable Change by HAL Radio Button?
I am also curious what you are doing as your 'jog' commands seem to actually just move the origin using g10?
Chris M
- Topic Author
05 Feb 2016 14:36 #69652
That did the trick for me. (other than a couple of typos).
Now on to the next battle, I want to make the large ZW change depending on the state of a hal pin.
If false I'd like it to be black and ZW, if true blue and ZZ.
class HandlerClass:
def __init__(self, halcomp,builder,useropts):
self.builder = builder
self.jog_increment = self.builder.get_object('jog_increment')
self.g54inch = self.builder.get_object('g54inch_jog')
self.g54tenth = self.builder.get_object('g54tenth_jog')
self.g54hundredth = self.builder.get_object('g54hundedth_jog')
self.g54thousandth = self.builder.get_object('g54thousandth_jog')
def activ_inc(self, widget):
if widget.get_active():
if widget == self.g54inch: self.jog_increment.set_text('1.000')
elif widget == self.g54tenth: self.jog_increment.set_text('0.100')
elif widget == self.g54hundredth: self.jog_increment.set_text('0.010')
elif widget == self.g54thousandth: self.jog_increment.set_text('0.001')
# This is boiler code, required for gladevcp
def get_handlers(halcomp,builder,useropts):
return [HandlerClass(halcomp,builder,useropts)]
06 Feb 2016 02:16 - 06 Feb 2016 02:17 #69687
You should be able to change this to what you want
Chris M
Replied by cmorley on topic Lable Change by HAL Radio Button?
import hal_glib
import hal
import pango
class HandlerClass:
self.halcomp = halcomp
self.g54tenths = self.builder.get_object('g54tenth_jog')
self.g54hundredths = self.builder.get_object('g54hundedth_jog')
self.g54thousandths = self.builder.get_object('g54thousandth_jog')
self.z_label = self.builder.get_object('z_label')
self.w_label = self.builder.get_object('w_label')
self.example_trigger = hal_glib.GPin(halcomp.newpin('label-trigger', hal.HAL_BIT, hal.HAL_IN))
self.example_trigger.connect('value-changed', self.on_label_trigger_value_changed)
self.attr_true = pango.AttrList()
fg_color = pango.AttrForeground(65535, 0, 0, 0, -1)
size = pango.AttrSize(30000, 0, -1)
weight = pango.AttrWeight(pango.WEIGHT_BOLD, 0, -1)
self.attr_true.insert(fg_color)
self.attr_true.insert(size)
self.attr_true.insert(weight)
self.attr_false = pango.AttrList()
fg_color = pango.AttrForeground(0, 0, 0, 0, -1)
self.attr_false.insert(fg_color)
self.attr_false.insert(size)
self.attr_false.insert(weight)
def on_label_trigger_value_changed(self, pin):
state = pin.get()
if state:
self.z_label.set_attributes(self.attr_true)
self.w_label.set_attributes(self.attr_true)
else:
self.z_label.set_attributes(self.attr_false)
self.w_label.set_attributes(self.attr_false)
elif widget == self.g54tenths: self.jog_increment.set_text('0.100')
elif widget == self.g54hundedths: self.jog_increment.set_text('0.010')
elif widget == self.g54thousandths: self.jog_increment.set_text('0.001')
Chris M
Last edit: 06 Feb 2016 02:17 by cmorley.
The following user(s) said Thank You: Todd Zuercher
- Topic Author
09 Feb 2016 15:32 - 09 Feb 2016 16:49 #69854
Thanks alot. Here is what I think I'll end up using.
import hal_glib
import hal
import pango
class HandlerClass:
self.zw_label = self.builder.get_object('zw_label')
fg_color = pango.AttrForeground(0, 0, 65535, 0, -1)
state = pin.get()
if state:
self.zw_label.set_attributes(self.attr_true)
self.zw_label.set_text('ZZ')
else:
self.zw_label.set_attributes(self.attr_false)
self.zw_label.set_text('ZW')
elif widget == self.g54hundredths: self.jog_increment.set_text('0.010')
Last edit: 09 Feb 2016 16:49 by Todd Zuercher.
10 Feb 2016 01:35 #69897
glad your getting closer to your goal!
Chris M
Chris M
Time to create page: 0.159 seconds
