GladeVCP References
29 Mar 2016 00:57 #72281
by squan09
GladeVCP References was created by squan09
Are there any references to find lists of attributes for objects related to GladeVCP? The particular error I am getting now is 'GPin' object has no attribute 'set_value'.
Similarly, I am looking through the custom GUI tutorial and see these lines:
self.status.poll()
data = self.status.actual_position[0]
Is there a reference that lists the functions like poll() or actual_position?
self.status.poll()
29 Mar 2016 06:20 #72293
Replied by cmorley on topic GladeVCP References
The following user(s) said Thank You: squan09
29 Mar 2016 19:56 #72347
by squan09
Replied by squan09 on topic GladeVCP References
Thanks for that. Everything is starting to make more sense.
30 Mar 2016 06:43 #72365
by newbynobi
Replied by newbynobi on topic GladeVCP References
pin.set(1.0) will set the pin to value 1.0
pin is a little but strange, as most widgets gets there value through set_value.
Norbert
Norbert
30 Mar 2016 19:46 #72410
by squan09
That didn't seem to work for me. I'm not sure if I have the syntax calling the pin right. This did work for me though: self.halcomp = 0, but it only works for pins defined in the python code.
Is it possible to set any pin from python?
Time to create page: 0.156 seconds
