Label for timers
07 May 2016 10:16 #74337
by tommy
Label for timers was created by tommy
I'm trying to implement timers found in following topic to my gladeVCP:
TIMER in pyVCP
I'm not sure how to properly format Hal_label so it would have colons between hours, minutes, seconds, as .ui file does not exist in my configuration, so all formatting is done trough glade editor.
PS.: my base gladeVCP is taken from manulatoolchange configuration.
TIMER in pyVCP
- Thank you received: 1369
07 May 2016 12:08 #74339
Replied by Todd Zuercher on topic Label for timers
I have a timer set up with a gladevcp in a config, but I"ll have to hunt down the config files, (they are at work.)
07 May 2016 17:45 #74344
by tommy
would be nice to see an example yes
Replied by tommy on topic Label for timers
07 May 2016 23:43 #74351
08 May 2016 02:55 - 08 May 2016 02:55 #74352
Basically the trick to making the hours, minutes, seconds display look like H:M:S is to set it up as 3 separate hal lables seperated by 2 ordinary lables for the colons. So you will have a hal lable for Hours, then an ordinary label for a colon, then a hal label for the minutes, then lable colon, then hal label for the seconds. Maybe there is a better way but that is how I did it.
TIMER in pyVCP
Last edit: 08 May 2016 02:55 by Todd Zuercher.
11 May 2016 12:48 #74503
by tommy
It works nice, I managed to implement those two timers (cycle and cumulative).
Now I wanted to do some visual refinements on my gladeVCP contents but I have grayed out Edit button and that triangle sign saying: "This property is not supported in libglade format".
Is there any other way to format my contents (increase font, bold, etc...)?
11 May 2016 13:12 #74506
I'm not sure what "Edit button and that triangle sign" your reffering to.
Normally to change the font properties of a label, scroll down and click the Attributes radio button under Edit Label Appearance, then click Edit. This will open a window with a bunch of options for controlling the appearance of the text in the label.
Alternatively there are ways of controlling a labels appearance dynamically from the python file.
11 May 2016 13:28 #74507
by tommy
11 May 2016 13:34 #74508
What versions of Linux and Glade are you running?
11 May 2016 13:47 #74511
by tommy
LinuxCNC 2.7.3
Glade: 3.8.0
Debian wheezy
PS.: If I open your dig5.glade file in glade, Edit button is not grayed out.
LinuxCNC 2.7.3
Glade: 3.8.0
Debian wheezy
