Newbie to GladeVCP
09 Mar 2017 16:56 #89264
by AThayer
Newbie to GladeVCP was created by AThayer
I was wondering if someone could explain what I need to put in the Ini file so that I can start trying out GladeVCP? Also can I use one of the example files that is included with linuxcnc 2.7 weezy? Also can modify one of the example files to start my own VCP? Thanks
09 Mar 2017 17:16 #89267
Replied by andypugh on topic Newbie to GladeVCP
What you put in the INI depends on how you want to use GladeVCP. It can be standalone or embedded in existing GUIs, either as a tab or a sidebar.
(Detailed in the documentation
Editing an existing Glade file is probably a reasonably good idea, the editor takes a bit of getting used to. (and seems to crash a lot. save often)
09 Mar 2017 17:20 #89269
by AThayer
Replied by AThayer on topic Newbie to GladeVCP
I tried what is in the documentation put I didn't get a GUI or a new tab. So I was wondering if I was doing it right?
09 Mar 2017 18:58 #89280
Start LinuxCNC from the command-line (command "linuxcnc") and you might get a clue in the output what is going wrong.
09 Mar 2017 21:33 #89294
by AThayer
Ok what fold is ../? I get axis but not a gladeVCP panel. I was wondering if it was looking in the wrong folder?
09 Mar 2017 23:56 #89303
by BigJohnT
What exactly did you put and where?
JT
Replied by BigJohnT on topic Newbie to GladeVCP
JT
10 Mar 2017 00:24 - 10 Mar 2017 00:25 #89307
../ is the folder that contains the current folder.
Last edit: 10 Mar 2017 00:25 by andypugh.
10 Mar 2017 00:26 #89308
by AThayer
GLADEVCP= -u ../gladevcp/hitcounter.py ../gladevcp/manual-example.ui
10 Mar 2017 00:28 #89309
by AThayer
So how does it know where to find.
10 Mar 2017 00:56 #89310
by AThayer
So do I need to put files in the same folder as my Ini file?
