GladeVCP HAL pin not found
23 Mar 2017 14:47 #90120
by Chre9
GladeVCP HAL pin not found was created by Chre9
Hey guys,
I need some help setting up a GladeVCP panel on gmoccapy. I haven't done this before and LinuxCNC can't find the HAL Pin, that should be created by Glade.
I created a panel (status.glade) with 3 LEDs and want to connect the first one to a physical HAL pin. What is the name of the HAL pin, that is created by Glade? gladevcp.hal_led1? Every time I try to open gmocoapy there is an error, that the pin wouldn't exist. I also tried to set the name in hal-pin-changed.
In Ini I use:
EMBED_TAB_NAME = status
EMBED_TAB_LOCATION = box_cooling
EMBED_TAB_COMMAND = gladevcp -x {XID} -H custom_postgui.hal status.glade
Postgui-file includes:
net button_1 gladevcp.hal_led1 <= hm2_5i20.0.gpio.054.in_not
What am I missing?
I hope this is all the relevant information, if you need more just ask
Greetings, Christian
In Ini I use:
What am I missing?
23 Mar 2017 17:32 #90132
Replied by andypugh on topic GladeVCP HAL pin not found
In the custom_postgui HAL file put the line
show pin
right at the top.
Then start LinuxCNC from the command line (command "linuxcnc") and you should get a list of all the pins that exist at that point.
My guess is that the pin in gladevcp.hal-led1 not gladevcp.hal_led1, but this test will confirm.
show pin
right at the top.
24 Mar 2017 03:45 #90171
Replied by cmorley on topic GladeVCP HAL pin not found
also check the INI file, under the HAL heading that you are not loading a custom_postgui.hal file there.
That is a common entry but won't work if you wish to load that file through gladevcp.
Chris M
Chris M
The following user(s) said Thank You: Chre9
24 Mar 2017 03:46 #90172
I am meaning that you can't load the same HAL file in two places.
Chris M
Chris M
24 Mar 2017 12:30 #90193
by Chre9
Replied by Chre9 on topic GladeVCP HAL pin not found
custom_postgui.hal is not in the hal heading, so this should not be the problem.
I added "show pin" to the top of the file and as long as I have
#net button_1 gladevcp.hal_led1 <= hm2_5i20.0.gpio.054.in_not
I can see, that the pin is called "status.hal_led1".
The problem is as soon as I remove the # in front of the line linuxcnc crashes again while starting,
telling me, that status.hal_led1 does not exist.
24 Mar 2017 12:37 #90194
Some confusion here.
The HAL line that is commented out does not reference a pin called "status.hal_led1" it references one called "gladevcp.hal_led1". It is very unlikely that uncommenting a line in HAL will cause an error message to appear that references a pin that is not part of the commented-out line.
What happens if you edit that HAL line to refer to status.hal_led1 and then uncomment it?
24 Mar 2017 12:44 #90195
by Chre9
Right, I changed gladevcp.hal_led1 to status.hal_led1 after seeing, that it's the name of the pin.
Sorry for being so unclear!
So if I uncomment it I get the error
24 Mar 2017 12:47 #90197
So, it tells you that the pin does exist in the pin list, then tells you that it doesn't exist in an error message?
Are you _absolutely_ sure that the INI file is not referencing the same postgui HAL file?
Maybe change the name of this HAL file, just to be certain.
24 Mar 2017 13:10 #90202
by Chre9
You were kind of right, the Ini refers to a file called "postgui_call_list.hal", which includes the line "source custom_postgui.hal".
I don't know why it's in there, but it seems to have caused the problem.
I changed the name of the file and it works now.
Thanks for your help!
