Speedcontrol widget: increment parameter doesn't work
06 Jul 2017 20:08 #95450
by nebelnoir
Speedcontrol widget: increment parameter doesn't work was created by nebelnoir
linuxcnc 2.7.9.
gmoccapy interface
increment parameter -1 is ok,
increment parameter from 0.001 to 99999.0 work like -1
gmoccapy interface
12 Jul 2017 17:34 #95738
by newbynobi
Replied by newbynobi on topic Speedcontrol widget: increment parameter doesn't work
Hallo nebelnoir,
where did you change the settings?
If you did change it in the speedcontrol.py file, it will not have any effect, as that values will be overwritten with the settings from the glade file.
You need to change the increment value in he gmoccapy.glade file. Unforunately in 2.7.9 there is a small bug in combidro widget, witch will not allow to edit that file within glade. I corrected that bug, but it is not included in 2.7.9 je.
So you will need o open gmoccapy.glade wih an edior of your choice, I used gedit o check your error report.
Look for the speedcontrol widgets in that file and add to the corresponding section a new property like so:
the value 10 is the new increment.
Norbert
<property name="increment">10</property>
Norbert
