GladeVCP
20 Sep 2011 13:08 #13327
by psha
Replied by psha on topic Re:GladeVCP
replace pyvcp.count with gladevcp.hal_label_count in M123
20 Sep 2011 14:35 #13330
by piasdom
Replied by piasdom on topic Re:GladeVCP
THANKS ! that was dumb of me.
but i still get the error about bit and s32/float/u32.
kenneth
kenneth
20 Sep 2011 16:52 - 20 Sep 2011 16:57 #13332
by piasdom
the action MDI prop is named gladevcp.MDI_M124_count and i have the below in my posthal.hal.
gladevcp.M124_count is the name of the hal label in glade. i get the error msg that
pin does not exist. is it possible at ALL to get a bit in glade ?
just yes or no will be fine
net MDI_Count conv-bit-u32.2.in == gladevcp.MDI_M124_count
net Count_out conv-bit-u32.2.out == gladevcp.M124_count
kenneth
kenneth
Last edit: 20 Sep 2011 16:57 by piasdom.
20 Sep 2011 18:12 - 20 Sep 2011 18:23 #13334
by piasdom
well i came up with the below. emc starts and the reset button works
do get error msg when clicking reset during program run. the pins/signals
show in HAL configuration. but it doesn't count M124.
net MDI_Count conv-bit-u32.2.in == halui.mdi-command-06
net Reset_count halui.mdi-command-05 gladevcp.Reset_M124
kenneth
i change he text template and the difference shows in axis.
kenneth
Last edit: 20 Sep 2011 18:23 by piasdom.
22 Sep 2011 09:45 #13351
by piasdom
i get the error "named parameter not terminated".
i'm trying to use the below script. is the error coming from
the script or emc ? emc starts with no errors but i get
the msg when i click reset(first script). when i use the scripts in MDI,
no errors on either.
#!/bin/bash
halcmd setp gladevcp.Reset_M124 0
exit 0
#!/bin/bash
COUNT=$(halcmd getp gladevcp.M124_count)
let "COUNT += 1"
halcmd setp gladevcp.M124_count $COUNT
exit 0
kenneth
#!/bin/bash
exit 0
#!/bin/bash
let "COUNT += 1"
exit 0
kenneth
22 Sep 2011 16:35 - 22 Sep 2011 17:42 #13363
by piasdom
JFYI
the "home all" and home "XYZ" buttons are not disabled
while program is running in glade panel.
i have a gtkbutton linked to a MDI command and a hal
button linked to halui.jog. .+-.
if i click the MDI button and then the halbutton. the halbutton(jogging)
doesn't work. i have to use Home All or use axis default jog, then
they work as should.
kenneth
kenneth
Last edit: 22 Sep 2011 17:42 by piasdom.
29 Sep 2011 17:53 - 29 Sep 2011 18:07 #13543
by piasdom
using the "abort" button(halbutton) after using the pause(gtkbutton) sometime hesitates(bout 5 - 7 sec).
other times get error about "file ended with no % sign or program end) same file just used the abort,
have to reload file or same error when using run button.
stop button(tried all type buttons) hesitates(bout same above) and sometimes hesitates and then gives
error msg and can't do that while in some mode and interpreter idle(can't remember exact, deleted button)
p.s. this is a side panel(not tab)
kenneth
kenneth
Last edit: 29 Sep 2011 18:07 by piasdom.
Time to create page: 0.079 seconds
