axis are moving but direction is wrong
11 Aug 2011 14:02 #12414
by wbeppler
Elektronik u. Softwareentwicklung
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
DE-78355 Hohenfels-Kalkofen
This email address is being protected from spambots. You need JavaScript enabled to view it.
axis are moving but direction is wrong was created by wbeppler
hello,
my machine is moving now but only x axis is ok like it is.
x has reference switch left and zero is left, too. moving to right is up to 200 mm, nice
y is a table and has reference switch when table is in front, so i should change direction, but how to do this ?
i do not want to invert in servo amplifier. i think it's better to do this in hal or ini
and now, my worst.
z has refernce swich when it is up. so all coordinates in z are negative. but when z travels down, it counts up.
if i invert my servo amp, so it drives wrong direction to search reference ???
so i need to know:
- how to change search-reference-direction ?
- how to change + and - direction ?
i'm nearly shure to do in the ini-file, but my english is not best, so i hope to get easy help here
thanks
wolfgang
moving-video of machine:
www.wolftec.biz/video/f2020_v1_beta.ogv
and now, my worst.
so i need to know:
thanks
wolfgang
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
11 Aug 2011 14:06 #12415
by BigJohnT
Replied by BigJohnT on topic Re:axis are moving but direction is wrong
Usually changing the sign of your scale is how you reverse directions when you press the + and - keys to move an axis.
By reference switch do you mean homing switch? In that case you also just change the sign of the search velocity and final velocity's for that axis in your ini file.
www.linuxcnc.org/docview/html/config_ini_homing.html
11 Aug 2011 14:32 #12421
by wbeppler
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
Replied by wbeppler on topic Re:axis are moving but direction is wrong
YES, YES, YES...
it works....
now i have to learn how.
thanks
sorry if i write about reference and not "home", but translation from german to english is sometime difficult because of slang
.... i'l try to go better
it works....
thanks
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
11 Aug 2011 14:41 #12423
by BigJohnT
No problem your English is fine and much better than my German as I only remember a couple of words (einfahrt and ausfahrt from the signs at McDonalds in Germany). But it has been a long time since I've been there...
18 Aug 2011 14:33 #12585
by wbeppler
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
new problems homing my axis
last edition i made by step and direction and homing only by swich
now im using servo with +-10V and index-encoder
so i want to home by driving to switch and then back to first index-signal
but nothing works. when i start emc2 always the x position is at 90.123 and if i klick home it moves onyl 0.001 or 0.002 and the the mark is set. the 90.123 still is visible and i know that i can configure in ini home_offset and home, but both are 0.
the axis do not move to any switch. but in my hal i connected the hm2_5i20.0.gpio.068.in to my x-home-sw
how can i thest more ?
or what can i try to do ?
thanks !
im stil learning, stepper did work, now its time to servo...
thanks !
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
18 Aug 2011 15:28 #12590
Replied by andypugh on topic Re:axis are moving but direction is wrong
wbeppler wrote:
What happens if you comment out the home position link in HAL (keep your hand on the e-stop!)
I wonder if motor noise is triggering the home input?
I have heard talk of some difficulties with index-homing, which version of EMC2 are you using?
18 Aug 2011 15:57 #12594
by wbeppler
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
they are moving !
thanks to andypugh for idea to comment some lines.
i had a home_sequence not 0 but not configured other sequences. so nothing did
I hope my stupid question can help other
best regards
w
best regards
w
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
Time to create page: 0.127 seconds
