Stepper moving in only one direction
02 Oct 2011 00:44 #13590
by tduckman
Stepper moving in only one direction was created by tduckman
I have my stepper wired up correctly(I think/hope/maybe not) When using stepconf or after loading up the example and doing individual steps I can turn my stepper clockwise clicking the + 10 times yields the following results:
1,2,3,4,no step,6,7,8,9,no step
When I click the - 10 times I get the following movement:
right,left,right,left,so step,right,left,right,left,no step
I have a bi-polar stepper wired up as a unipolar.
Only testing one axis now as I assume the other two would act the same.
Thank you
tduckman
Thank you
tduckman
02 Oct 2011 08:13 #13598
by cncbasher
Replied by cncbasher on topic Re:Stepper moving in only one direction
you have an incorrect phase somewhere , or one phase reversed
without the wiring diagram it's difficult to pin point further ,
if you can give information as to your stepper motor and stepper driver and wiring we can advise further
03 Oct 2011 09:03 #13622
Replied by andypugh on topic Re:Stepper moving in only one direction
tduckman wrote:
Alternatively, you might just need to switch the polarity of your step signal. (ie, invert the pin, either in stepconf of HAL)
I can't quite explain the no-step (though that could be due to inaccurate microstepping) but the rest of it sounds very much like step and enable pins are swapped.1,2,3,4,no step,6,7,8,9,no step
Time to create page: 0.060 seconds
