Two stepper motors on one axis - help needed
23 Oct 2011 18:04 #14138
by DaveAK
Two stepper motors on one axis - help needed was created by DaveAK
I have a small micro gantry system which has two steppers driving the X-axis. I had it working a couple of years ago but it's been gathering dust since. I just went to resurrect it with a new install (2.4.6, upgrading now to 2.4.7) and I've run in to a problem. When I issue a G0 X1 for testing it works fine, but when I do G0 X0 to go back to the original position one of the X-axis goes in the correct negative direction, while the other continues to go in the positive direction. Any suggestions on how to trouble shoot this would be welcome!
Although I've used it a couple of years ago I only used it briefly and hadn't dug deep in to any of the setup, so basically I'm a complete newbie - I just know that it's worked before so should work now.
23 Oct 2011 23:35 #14144
Replied by andypugh on topic Re:Two stepper motors on one axis - help needed
DaveAK wrote:
If it used to work, then I would suspect the direction wiring on the one that never changes direction.
If it has never worked, then the problem could be in the HAL file.
But my money is on a loose connection on a direction wire.
24 Oct 2011 00:52 #14147
by DaveAK
Replied by DaveAK on topic Re:Two stepper motors on one axis - help needed
Thanks Andy. The wiring is definitely not the best and was a very quick and messy job. Now that I've got it relocated I'll do a proper job and report back.
Time to create page: 0.056 seconds
