Z DIR PROBLEM AND OUT FOR RELAY
- cncdtgrouter
17 Nov 2011 16:13 #14904
by cncdtgrouter
Z DIR PROBLEM AND OUT FOR RELAY was created by cncdtgrouter
Can help any with this
Pin 1 estop
Pin 2 x step
Pin 3 x dir
Pin 4 y step
Pin 5 y dir
Pin 6 z step
Pin 7 z dir
Pin 8 Spindle on
Pin 9 unused
Pin 10 unused
Pin 11 unused
Pin 12 unused
Pin 13 unused
Pin 14 unused
Pin 15 unused
Pin 16 unused
Pin 17 Amplifier enable
test these settings on LPT port with led for high and low output
X - Y STEP AND DIR IS OK
Z STEP IS ok
The problem
Z DIRECTION IF MOVE DOWN IS ON THE LED IS OK BUT
Remain open until completion at the bottom . When move up is closed
The other problem pin 8 for the relay does not switch low or high why
Pin 1 estop
Pin 2 x step
Pin 3 x dir
Pin 4 y step
Pin 5 y dir
Pin 6 z step
Pin 7 z dir
Pin 8 Spindle on
Pin 9 unused
Pin 10 unused
Pin 11 unused
Pin 12 unused
Pin 13 unused
Pin 14 unused
Pin 15 unused
Pin 16 unused
Z STEP IS ok
The problem
17 Nov 2011 18:20 #14908
by BigJohnT
Replied by BigJohnT on topic Re:Z DIR PROBLEM AND OUT FOR RELAY
Direction pins only change when a direction change is needed, so it is normal for the direction pin to stay on after a move.
How are you testing pin 8?
If your using M3 or M4 without setting S to some number above 0 the spindle pin stays off.
- cncdtgrouter
18 Nov 2011 10:31 #14914
by cncdtgrouter
Replied by cncdtgrouter on topic Re:Z DIR PROBLEM AND OUT FOR RELAY
is ok now with default gcode file no working pin 8
with my file is ok the pin 8
Time to create page: 0.056 seconds
