What am I doing wrong? (Mill vs Lathe speed)
05 Dec 2011 00:07 #15384 by Harry_Y
BigJohnT wrote:
If your using 2.4 you should be able to open up your lathe config and select 3 axis and go to the Y axis page and set max velocity to .1 or something lower than X and Z then go back to the first page and select XZ Lathe. If your making changes to your config using stepconf this will preserve your max velocity slider at 24 I think.
That fixed it, Thank you
Time to create page: 0.179 seconds
