Bridgeport Series II Interact 2 Conversion
05 Jul 2013 07:33 #36320
by danande
Replied by danande on topic Bridgeport Series II Interact 2 Conversion
How did this turn out?
I have bought the same machine and I want to convert to emc2 and reuse the old encoders and motor amps.
What did you use for I/O ?
Dan
Dan
05 Jul 2013 10:04 - 05 Jul 2013 10:11 #36324
by KPA
Replied by KPA on topic Bridgeport Series II Interact 2 Conversion
Well it's still sitting in my garage apart.. it'll get done one of these days. I'm patient and trying to chew through my chore list before I can get to it. But in the end my decision is either get the 602 D or E interpolation boxes or go big and put an Ajax system in it. Trying to reverse the system boards was too much effort for too little return given the availability of the interpolation boxes and my lack of that depth of knowledge. Encoders and motors I have confidence in. The amps I'm not sure about.
What I really am not sure about is the overall functional performance of a LinuxCNC system with my old amps compared to the Ajax system. If anyone can provide a objective comparison I'm all ears!!
Jay
Jay
Last edit: 05 Jul 2013 10:11 by KPA.
12 Aug 2013 23:19 #37590
by danande
Well if the amps work I don't see the point in spending all that money on new amps..
Can I use a Heidenhain exe 610b instead of a 602? Found some cheap ones on ebay..
www.lna.br/~det/Projetos/TCSPD/doc/HeidenheinEXE602.pdf
The pdf above lists the 610c to be 5or 10fold and 2mhz clock frequency, is this good or bad? The 602 is non or 5fold and non clocked.
Not sure what the difference on the b or c models is.
Dan
Dan
06 Dec 2016 21:18 #83721
by moise
Replied by moise on topic Bridgeport Series II Interact 2 Conversion
bonjour Messieurs
mon moulin est tombe en panne briddgeport 412 interact tnc 355 a cause d'un encodeur ERO 115-125 sur servomoteur SEM
MT30M4-24 est ce qu'il ya un encodeur qui peut remplace ERO 115-125 avec les meme caracteristiques. toutes aide sera appressier merci d'avance
MOISE
MOISE
Time to create page: 0.094 seconds
