THC config that works.
- Topic Author
- Thank you received: 5904
23 Apr 2017 12:11 #91883
Replied by tommylight on topic THC config that works.
Download the config again and start from the begining, you made to many changes to things you do not have to change.
Do not change anything except the pin numbers and input polarity ( -in or -in-not ).
03 May 2017 18:17 #92591
by beauxnez
Replied by beauxnez on topic THC config that works.
Hello
since i have changed the bob ca works except that if i remove the # in front of the "net EstopLatchDog" ca do i can not run linuxcnc on
the output p17 I have to put that? Because on google translation it is not clear
C is an exit but towards what?
You do not have a picture or schema
- Topic Author
03 May 2017 21:35 #92600
What is your native language?
04 May 2017 04:17 #92618
by beauxnez
French
04 May 2017 15:31 #92652
Feel free to ask the question here in French.
You can also ask on the dedicated French Language part of the forum:
forum.linuxcnc.org/46-francais
Replied by andypugh on topic THC config that works.
French
04 May 2017 16:39 #92664
by beauxnez
Je dois connecter quoi sur le pin 17 ?
- Topic Author
05 May 2017 09:46 #92685
Beauxnez
I will have a look again tonight , sorry for the late reply.
05 May 2017 10:02 #92687
by beauxnez
Pas de problème
Merci de votre aide
Merci de votre aide
- Topic Author
05 May 2017 22:18 #92721
Here is the config with some more details on how to set up, but it is for Linuxcnc 2.8pre,, so it will not work on 2.7.
Unfortunately i do not speak French, i was in Paris for only 3 weeks.
Let's try again to make this work, thank you for your patience.
Tom.
Tom.
06 May 2017 07:02 - 06 May 2017 07:05 #92730
by beauxnez
Hello, thank you.
I have to search last night I think it must work. I finished my thc with an arduino this week, I simulated the voltage with a potentiometer and I have my lights up, down and arcok that lights on the screen.
I still have to do a test of my voltage divider and see if all this works well
Last edit: 06 May 2017 07:05 by beauxnez.
Time to create page: 0.103 seconds
